Old 05-07-2014, 02:32 PM   #1
BADAZ chevy guy
BADAZ chevy guy's Avatar
serpentine belt conversion
I know there must be a thread here someplace that has all this info, I just can't find it. I have a 1977 C10 and I want to do a serpentine conversion. What year(s) are best for pulling parts from and what parts do I need? Also, are there any videos on the actual install?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 05-07-2014, 02:34 PM   #2
JWall
Frequent Flyer
JWall's Avatar
Re: serpentine belt conversion
Good info here... http://67-72chevytrucks.com/vboard/s....php?p=6569325
- Justin
1 Owner 1976 SWB
Old 05-07-2014, 03:23 PM   #3
bigd65
bigd65's Avatar
I did my 85 awhile back, dont have that truck anymore. I do recall it was off of a 88 model I think, not a square body. also has to get a water pump from that year, has a reverse rotation. your old one will NOT work.... also there was something that had to be done with the alternator unless you have a serpentine belt pulley put on yours. I wanted the higher output alternator
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 05-07-2014, 11:01 PM   #4
notallthere
I find that the years 94-98 are the easiest to do. Make sure that you grab everything off the donor truck. If there is a bracket going somewhere get it. The alternator will be different and you will need a conversion clip for the hookup.
http://www.summitracing.com/dom/parts/pwm-140/overview/
Dorman industries does make a A/C condenser delete pulley if you need it.
notallthere is offline   Reply With Quote
Old 05-07-2014, 11:18 PM   #5
BADAZ chevy guy
Do you know which compressor was stock on the 94-98's?
Old 05-07-2014, 11:22 PM   #6
notallthere
94/95
http://www.oreillyauto.com/site/c/de...2645&ppt=C0354
96-98
I do prefer the 94/95s the most and I have done them on a few trucks and cars.
Old 05-08-2014, 02:10 AM   #7
BADAZ chevy guy
94/95
96-98
Okay. Thank you. I'll start looking next time I get money.
Old 05-08-2014, 03:33 AM   #8
bigd65
bigd65's Avatar
If I'm not mistaken, I may be backwards... But the older ones are a ONE PIECE BRACKET. still need the support for the AC though.... And you are correct about the alternator.
2017 Chevy Tahoe
Old 05-08-2014, 06:40 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The 88-89 version of the brackets were steel and a poor design. They often cracked and broke bolts off in the block. So much so, that GM was forced to redesign them in 1990 due to excessive warranty claims.
Here is the 88-89 type (off of my old 89).
So, they redesigned them to the aluminum brackets. These were splendid and bulletproof. They're ideal for a conversion. I just converted my 4x4 from the (broken) steel bracketry to the later aluminum ones last weekend. These brackets were used from 1990-1995. The power steering pump, alternator, AC compressor and all pulleys directly interchange from the steel 88-89 brackets and the aluminum 90-95 brackets.
Then, in 1996 when the Vortec engine came out, the brackets changed again. The alternator and air conditioning compressor swapped places. Also, the new type of AC compressor came into play. I do not have any pictures of these brackets as I haven't personally done one of those swaps yet. So, I stole one from Google.
Something I did learn this weekend, and it's a biggie, you can reuse your original power steering pump when you convert to serpentine. The serp pulley simply presses onto the pump in place of the V belt type of pulley. I wound up using an 87 model V belt power steering pump on my 4x4 with the 90-95 type aluminum serpentine brackets. No mods. Just make sure you press the pulley on the proper distance as the earlier pumps used a slightly shorter shaft and the pulley doesn't press on flush like it did on the serpentine application. You'll see the witness mark where the old V belt pulley wasn't pressed on flush either so GM did it that way purposefully.
Old 05-08-2014, 09:43 AM   #10
JWall
Frequent Flyer
JWall's Avatar
Well I learned something today. I had wondered about the change.
I have the 88-89 style on my 76 & have had good luck with it... of course now I will have paranoia about my set up
- Justin
1 Owner 1976 SWB
Old 05-08-2014, 10:00 AM   #11
Tx Firefighter
The 88-89 type aren't so bad as long as all bolts are present and fully torqued and the support rods between the brackets and engine are all there. Loose bolts or missing rods will cause cracks eventually. It's guaranteed.
But, while properly installed and in place they work fine. You can see my personal setup in the first few pictures, and I spent a bunch of time powdercoating them. They aren't anything to worry about if you install them properly.
Old 05-08-2014, 01:08 PM   #12
bigd65
bigd65's Avatar
OK so did I, i didnt realize they were a RE-DESIGN..... BUT i thought there was a ONE PIECE SET-UP
2017 Chevy Tahoe
Old 05-08-2014, 03:45 PM   #13
SCOTI
SCOTI's Avatar
Nope... 2 different brackets for both versions.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-09-2014, 12:09 AM   #14
bigd65
bigd65's Avatar
88-91 ONE PIECE BRACKET.... Same as I have put on my 85
Well search it on this forum. I just found it but can't figure out how to post the picture....
2017 Chevy Tahoe
Old 05-09-2014, 02:22 AM   #15
83GMCK2500
I dug into the parts catalog...they have them broken down in two-year chunks. I did not go through each section checking part numbers, I was just after the pictures, hoping they'd help everyone visualize the differences.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-09-2014, 05:26 PM   #16
DREAMER1
DREAMER1's Avatar
I did the conversion using the 94 bracket and so far I've had to change out the water pump, alternator and the power steering pump. Not to mention I had to drill and tap a hole in one of my heads.
DREAMER1 is offline   Reply With Quote
Old 05-09-2014, 05:50 PM   #17
Tx Firefighter
Why did you have to change your power steering pump ?
Old 06-09-2016, 07:26 AM   #18
slimneverdies
slimneverdies's Avatar
I have the 88-89 style brackets for a 454 big block. Do you know if this style alternator would fit the brackets if I changed the pulley on front of it? curious if the holes line up and also the serpentine pulley. Its brand new so I don't want to buy another one
http://m.summitracing.com/parts/pwm-47294
http://i755.photobucket.com/albums/x...pslv4w2e7g.jpg
also, where do I get the supporting bolts and tension pulleys for the brackets?
thanks
Slim
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
