Old 05-07-2014, 10:32 PM   #1
dwlambert1701
Torq specs for trailing arm and track bar
I have a 1963 C10. I'm replacing the bushings in the trailing arms and the track bar. What are the torque specs for those two areas.
dwlambert1701 is offline   Reply With Quote
Old 05-08-2014, 10:00 AM   #2
morethanstock66
morethanstock66's Avatar
Re: Torq specs for trailing arm and track bar
I've always used 55lb/ft. on dogbones and track bars and have not had any problems. As to the "correct" specs, I am not sure, sorry.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 05-08-2014, 10:35 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
The spec I have for the trailing arm pivots is 140 ft/lbs. The track bar is 60 ft/lbs IIRC.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-08-2014, 10:38 AM   #4
dwlambert1701
Thanks wanted to find that out before a got them back on.
