Old 05-08-2014, 12:36 AM   #1
ronniehotdog
ronniehotdog's Avatar
What bag system to go with ?????????????
I want to build my first 65 with bags front and rear. I think I am going to go the cheap easy way. clip and z the front. My question is what is the cheapest bag system that works, what size and brand of bags to use.
ronniehotdog is offline   Reply With Quote
Old 05-08-2014, 02:46 AM   #2
andrewmp6
Re: What bag system to go with ?????????????
Are you trying to lay frame or not ?
andrewmp6 is offline   Reply With Quote
Old 05-08-2014, 10:03 AM   #3
ronniehotdog
Yes I want to lay the frame
Old 05-08-2014, 12:35 PM   #4
Pro Performance
Pro Performance's Avatar
There are a lot of ways to build your own suspension system, and the air management is really what will vary the pricing. Single or dual compressors? Manual valves or e-level? Individual valves or the VU4? Either way you go, I do suggest getting quality parts, because it will pay off in the long run and save you a lot of headaches.
As for bags, I would suggest the AirLift D2600 bags up front. You can use them in the rear, but all depends on how you will be setting that up. Some like to use the sleeve bag.
Pro Performance is offline   Reply With Quote
Old 05-09-2014, 02:06 AM   #5
andrewmp6
Have you z a frame before?If not its a big job and has to be done right.
Old 05-09-2014, 11:59 AM   #6
tinydb84
tinydb84's Avatar
Cheap and Easy don't go together that well...
Cheap: Front and Rear Z with manual valves
Easy: Front and Rear Porterbuilt/Scotts with a valve block.
David
Instagram: myfabguy
