Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-08-2014, 01:32 AM   #1
Sid138
Sid138's Avatar
Drag Race Class Confusion
I realize that class rules, specs and regulations are in abundance all over the internet, but it seems when I look up classes, the terminology is for those that are veteran racers that already understand, or at least have a good idea of the class they should run.
To make matters worse, it seems as though a lot of classes are relatively the same to me, and I can't figure out the difference.
Could someone please "mentor" me in getting started and assist me with rules and regulations?
To get the ball rolling, my local Drag ways Farmington, NC and North Wilksboro, NC are all 1/8 mile.
Currently my truck is a '72 C/10,
350ci SBC, but was originally a 6cyl., if that makes a difference,
TH350 tranny with a shift kit, B&M MegaShifter
The only mods to the '73 engine is a VooDoo cam with a max .504 lift
HEI dizzy,
Holley 670 Street Avenger carb,
Edelbrock RPM Air Gap intake,
Aluminum heads with 2.02/160 valves
Full length headers with flowmasters
Original 12 bolt rear, w/3:73 open diff (for now)
Street tires, 295/50/15 @ 4 corners
Lap belt only, no bars or cage of course
What class would I fall under with this set up?
Near future modifications:
All the above, but mostly forged internals after rebuild possibly bored .30 over,
Small baby blower (Weiand 142 or 144 between 5-8lbs boost)
Wide slicks with 15x10 or 15x12,
Forced induction and/or slicks toss me into another class, right?
My apologies for lack of knowledge and any vital info that I didn't mention.
All advice would be greatly appreciated.
Thanks,
Sid
1972 C/10 short step, 327/TH350, Blue Print H8002k Aluminum heads, 268 Lunati Voodoo cam, Lunati lifters, valve springs, roller rockers and Summit Racing dbl roller timing chain, Holley 670 Street Avenger dual line carb, Edelbrock RPM Air Gap intake, Summit ceramic coated long tube headers, Flowmasters, 3:73 gear, 15x10 Wheel Vintique Rallys w/ 295/50 front and rear, 2/4 drop, Custom Sound Head unit, Alpine amp, Fosgate Punch P3, Kenwood 6x9 in the doors, Grant GT w/tilt, B&M MegaShifter...etc
Sid138 is offline   Reply With Quote
Old 05-08-2014, 07:06 AM   #2
PGSigns
PGSigns's Avatar
Re: Drag Race Class Confusion
Farmington runs Friday night thunder and I think that is the street cars. They do have a street class that is part of the points system. To get started go and watch. Look at the tech inspection and that staging lanes. Watch the way the street cars handle the water box. Most with treaded tires will drive around it. Keeps them from draging water to the starting line. Watch the way folks stage and how the tree works. Go to the other end and look at the way they go through the traps and get off the track. Look at the return road and where you get your time slip. All this will help you when you go to run for the first time. They run some fast cars down there with some of the racing they do.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-08-2014, 07:09 AM   #3
PGSigns
PGSigns's Avatar
One more thing. Once you get out of the street class and move up the next one with the stuff you have is the foot brake class. That place has a lot of hook on the starting line and if you have any weak links in your drive train "Mr Sticky" will find them.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-08-2014, 11:17 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
See if your local track has a sportsman or street no electronics class and just get started . They will check out or tech your truck . Make sure the battary hold down is sufficent , the radiator has and over flow catch can , that you have seatbelts , all your lugnuts are in place . Things like this . I started officially bracket racing 2.5 years ago after bracket racing for years . Just do it . You wont be great at first , but you will get better .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-09-2014, 12:46 AM   #5
Sid138
Sid138's Avatar
Jimmy
Thanks guys, the more I read up on classes and points..etc., I think I would be satisfied running test and tune/grudge racing to start out. It will get me on the track and familiar with the way things are done with the experience and advice of veterans such as yourselves.
Thanks again for your help, and I will mos def attend Friday Night Thunder at the Farm on the 23rd.
See you at the track
Old 05-09-2014, 09:16 PM   #6
PGSigns
PGSigns's Avatar
I first went down the drag strip in 1977. Ran local bracket races and IHRA and NHRA national events. It can be adicting and you can spend a fortune if you want. I sold the dragster and all my drag race stuff 2 years ago. You live and die by.001 of a second and that takes a little getting used to. Have fun with it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-12-2014, 12:27 AM   #7
Sid138
Sid138's Avatar
Jimmy
Thanks Jimmy
Old 05-12-2014, 06:57 AM   #8
PGSigns
PGSigns's Avatar
Super chevy is at Virginia motorsports park this weekend. Ill be at the swap meet friday and Saturday. Come on up and I will help with all your questions. Also good time to hunt for truck stuff.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
