![]() Join Date: Sep 2002
Question about auto shift linkage
Putting a 83 project back together and have a question about the auto linkage.
I noticed that the hole in the pivot ball (mounted on frame) where the shift linkage goes into it seems excessively large, compared to the linkage piece it holds. Am I missing a part or does the linkage just kinda flop around in the oversize hole? Any info is appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: Question about auto shift linkage
There should be a nylon spherical spring loaded piece that fits into the frame bracket (like a ball and socket arrangement).
Sounds like you are missing this nylon piece. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-08-2014 at 12:04 PM. |
I have the spring but missing the nylon piece.
Thanks Keith. Now I have to hunt down the part or at least a part number.
You are welcome.
You might be able to make one if you can't find it. It is hemispherical to fit into the bracket, with the diameter of the rod through it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
After some searching I found the missing piece.....whew.
