Differences between C10 and C20 cab mounts?
I need new cab mount bushings for my 71 GMC C20 and one site shows that they are all the same and LMC shows different pieces for the C20.
Does anyone know exactly what the differences are?
The Older Generation
Re: Differences between C10 and C20 cab mounts?
The C-20 rear bushings are taller because the frame brackets sit lower on the frame. LockDoc
yup I don't remember the exact difference, but about 2-3"
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
Might want to take a look at the factory manuals.
* VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID Blazer SPID Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thank, that clears that up pretty well.
#6 | |
It's a 68 C10 chassis with a 68 C20 cab. Last edited by mechanicalman; 07-21-2014 at 03:37 AM. Reason: additional info |
![]() Join Date: May 2003
I believe you'll find the cab is the same, it's the mounts on the frame that are mounted differently as LockDoc said. So you order the bushings for the frame.
So if you have a C10 frame & a C20 cab you order C10 bushings !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#8 | ||
That would be correct. The cabs are all the same the frame is the only difference.... LockDoc
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
The factory drawing for the C-KA10 is incorrect in the fact that they included the Ks in the mix. All 4X4s whether they are 1/2 ton or 3/4 ton had the taller rear cab mount pictured in the C-KA20/30 drawing. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
