05-08-2014, 05:14 PM | #1 |
Tire size & gear ratio
I need to change tire size and gear ratio on my 2003 ECM 5.3 4L65E, what is the easiest way.............least expensive?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
05-08-2014, 07:50 PM | #2 |
Re: Tire size & gear ratio
I did mine when I mailed the ecu off for tune
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
05-08-2014, 07:56 PM | #3 | |
meowMEOWmeowMEOW
Otherwise you've gotta mail-order it back to who tuned it for you, if the tune is locked. You may be able to try a flash tuner like an SCT or Diablo, but many of them also "lock" the tune. If you have HP Tuners yourself, you can just edit it in 5 minutes. Sure, $320 ain't cheap, but how many times do you have to pay someone a fee before you've paid yourself back?
05-09-2014, 08:53 AM | #4 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-09-2014, 08:55 AM | #5 | |
Brew - Quick question. I have my tune licensed through my HPTuners software, if another tuner were to plug his laptop and HPTuner interface into my ECM, would he be able to tune it without having to purchase a new license?
05-09-2014, 01:32 PM | #6 |
meowMEOWmeowMEOW
All of the info is stored in the INTERFACE BOX, not in the laptop, or the ECM. Take YOUR interface to his shop, and he SHOULD be able to tune it without applying extra cost.
If HIS shop doesn't already have the "unlocks" for your year, then technically, he may ask you to pay. Some shops give a flat hourly or per-tune rate, regardless of if they have to gain a license (cost of doing business), others charge you for that service.
05-09-2014, 09:35 PM | #7 |
Fabricate till you "puke"
How far are you moving the gearing/tire size? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-09-2014, 10:53 PM | #8 |
The old gear is a 3:42 and the new is a 3:25, tires are not selected yet but I am trying to stay within a 1" to 1 1/2 shorter
05-10-2014, 12:14 PM | #9 | |
Check this site and plug in new gears/tire size and old gears/tire size. You're RPM doesn't change much. http://www.ringpinion.com/Calculators/Calc_RPM.aspx
05-10-2014, 06:04 PM | #10 |
When you say will not affect much, do you mean the speedometer function?
05-10-2014, 06:54 PM | #11 |
Looks like your new gear choice will offset your new tire choice.
05-10-2014, 07:36 PM | #12 |
Thanks then I will run the computer tune that is in it now
05-10-2014, 09:47 PM | #13 |
Sounds like you are "good to go".... thanks for the calculations Hart rod I went from 3.42, to 3.73's on my 02, did not mess with anything. The speedo is 4-5 mph fast on the read @ hyway speed.....that will just keep me out of trouble Longhorn
