Old 05-08-2014, 05:15 PM   #1
fine 67
Junior Member
help question
back in 1972 did the blazer come with a top post or side post battery .when you look over the grill is the pos on the right or left thanks mark
fine 67 is offline   Reply With Quote
Old 05-09-2014, 10:35 AM   #2
pound41
Re: help question
There was a thread on this not too long ago
side posts
pound41 is offline   Reply With Quote
Old 05-10-2014, 04:14 PM   #3
Chulisohombre
Chulisohombre's Avatar
Re: help question
I didn't think side post existed back then. Anything that old always has top posts. And positive is usually on left. But anything can be changed. Ground should be on the engine block and positive direct to the starter from pisitive side of battery. Make sure where it is hooked up.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 05-12-2014, 01:55 AM   #4
iambigfattony
Re: help question
Looks like side post.
iambigfattony is offline   Reply With Quote
Old 05-12-2014, 03:33 AM   #5
Chulisohombre
Re: help question
That is top post in your pic tony.
Old 05-12-2014, 08:54 AM   #6
Togan66
Togan66's Avatar
Re: help question
The cables are for a side-post, if the cables are original......
Togan66 is offline   Reply With Quote
Old 05-12-2014, 09:29 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: help question
I dont rmember Any side post batteries in 72.
Tom Vogel is offline   Reply With Quote
Old 05-12-2014, 09:33 AM   #8
jaros44sr
jaros44sr's Avatar
Re: help question
I THINK pos must be on the right, because there is a clip for the cable to run to the starter...but i could be wrong
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-12-2014, 09:49 AM   #9
Chulisohombre
Re: help question
Either way need to hook up to battery correct whatever orientation of the wires. Positive to the starter and negative to ground bolt on the engine. Mine is bolted to the alternator mounting bracket.
Old 05-12-2014, 10:03 AM   #10
Togan66
Togan66's Avatar
Re: help question
http://www.automotive-fleet.com/arti...-gm-s-71s.aspx
This says the side post was available in '69 and became standard on most GM's in '71.
Old 05-12-2014, 04:22 PM   #11
Chulisohombre
Re: help question
I read another site that said side post batteries weren't available until 72. On that bulletin 80% of pontiacs and some light trucks used them in 71. So it's pissible became standard in 72 then. I've never seen a truck older than mid 80s with anything but too posts though. Guess its cheaper that way or else most wouldn't have been converted back to the older style.
Old 05-12-2014, 09:21 PM   #12
Mike C
Mike C's Avatar
Re: help question
My Jimmy came with side post battery.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-16-2014, 02:23 AM   #13
old man jimmy
Re: help question
yep, 72's came with side post...
old man jimmy is offline   Reply With Quote
