Old 05-08-2014, 09:54 PM   #1
recboy300
motor swap ???
can any one give me a direction on putting a 1979 350 in my 69 chevy. the mounts are different and didnt know if there was a conversion kit out there. it originally had a 292 in it if that helps any?? thanks
recboy300 is offline   Reply With Quote
Old 05-08-2014, 11:58 PM   #2
boynton
boynton's Avatar
Re: motor swap ???
you need a little...
the correct motor mounts (located in the correct v-8 location)
correct fan shroud
possibly a different radiator (the v-8 will need a larger radiator depending on heat output 3 core rad vs 4 core)
possibly trans crossmember relocation
possibly longer driveshaft
I think that is about it. The reason I use possibly in front of most of the items is it depends on what you have.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 05-12-2014, 05:38 AM   #3
recboy300
Re: motor swap ???
Yup got most of that didn't think about the drive shaft tho. I'm running electric fans on a new aluminum radiator so fan shroud won't be a problem. Just haven seen the mounts for a v8 of that year on a truck yet seance mine had a straight 6 thanks for the info. Looks like I'll be fabbing something up
Old 05-12-2014, 12:08 PM   #4
boynton
boynton's Avatar
Re: motor swap ???
You can get a pair of motor stands for about $20-$25 in the parts forum. It would probably be a lot easier than fabbing them.
1970 SWB Step-Side
Old 05-12-2014, 07:18 PM   #5
gdavis
gdavis's Avatar
Re: motor swap ???
I sent you a PM on the problems you will nun into with the swap. But there is a light at the end of the tunnel. I have posted a lot of pictures of the problems you will have. So go by and check out my build. I changed a 292 for a 350.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
