Old 05-08-2014, 10:56 PM   #1
Branman1971
Branman1971's Avatar
CPP Power steering bracket question
I got a CPP6066PSK power steering bracket kit and I don't know if this looks right. I haven't drilled anything yet but the instructions online say to bolt top left and bottom right bolts first for drilling. This kit is supposed to be for 60-66 and I have a 61. I included a picture of the outer bracket. Is it supposed to protrude above and below the frame like mine is?
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 05-09-2014, 12:02 AM   #2
luvbowties
luvbowties's Avatar
Exclamation Re: CPP Power steering bracket question
Why not return what you've got--or sell it on Craigslist--and buy CaptainFab's kit(He is a member of our forum.). His kit is made from HIS experience, is a quality unit, and even has templates included with his own "hands-on" instructions; and he is available on our forum for advice on any questions you may have.
Sorry about not able to answer your ????, but when those of us who cannot install/adapt via our own fabrication skills, I think it best to go with the Captain's 'tried-and-true', personal-experienced kits. Even feeling I have enough skills to adapt my own--and I've done several on these 60-66 trucks with NO bought adapters and NO knowledge of anyone's adapters--I still recently bought one of his kits, merely to compare to what I've been doing. If I were to do all my conversions again, starting from no experience, I'd have saved hours of time and countless re-do's if I had used his kits from the get-go--would've eliminated so many trial-and-errors; so many mis-placed holes that had to be welded-up; so much heating/forming/grinding/polishing of re-worked frame snouts. Did I say his kits eliminate wasted effort, time, money?
He even can tell you which steering boxes to buy, which ones to avoid, which pumps(some pumps take different hose ends) work with which boxes(some boxes take different hose-ends). He can explain[easily] what to do and why do it when you finish the conversion and suddenly you have a dangerous truck that steers adequately when making left turns but dangerously-short when making a right turn. Also, advice re: would you prefer extra-easy wheel-turning or a quicker,sporty-feel? Buy correctly with 1st purchase & learn how to determine correct one for your preference.
Why re-learn and re-write his encyclopedia of info that is already "published"? And, NO, I do not refer for commissions--but just for helping fellow truck-lovers.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 05-09-2014, 12:16 AM   #3
Branman1971
Sam, what a spokesman for Capt Fab you are! Unfortunately Capt fab does not yet make 60-62 brackets. I asked him personally. Nor did he have any 63-66 brackets available for purchase at the time when I tried to buy one from him. Great points though brother, he does make some nice stuff. I have seen it, which is why I went to him first.
1961 C10 SWB
1965 C10 LWB BBW
Old 05-09-2014, 12:30 AM   #4
Captainfab
60-66 Nut
Thanks for the sales pitch Sam
Branman take a look at this thread, it may help a little. It looks like you have the plate positioned correctly.
http://www.67-72chevytrucks.com/vboa...d.php?t=316388
Old 05-09-2014, 12:44 AM   #5
Branman1971
Thanks Captainfab. I looked all evening for a thread like that one. I'm not sure but I think I might have a problem with my pitman arm too. Didn't look like it was gonna work but I didn't get everything situated. Thanks again. Moving on!
1961 C10 SWB
1965 C10 LWB BBW
Old 05-09-2014, 12:08 PM   #6
61K10
61K10's Avatar
how wide is your frame on the 61 where the plate bolts?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-09-2014, 12:10 PM   #7
Branman1971
I will check when I get home. It's not a c-channel frame. It's square tubed.
1961 C10 SWB
1965 C10 LWB BBW
Old 05-09-2014, 12:24 PM   #8
61K10
61K10's Avatar
yes my frame is c-channel on my 4x4 and yours is boxed type. is the curve the same as the later c-frame? I would try and mount it so your pitman arm lines up correctly.
1961 chevy K10
Old 05-09-2014, 03:25 PM   #9
speeddemon6269
Looks good, just did one on my 62. The two holes that protrude above and below the frame should be threaded. You will drill out the same two holes on the gear box and install the bolts from the opposite side.
speeddemon6269 is offline   Reply With Quote
Old 05-09-2014, 04:51 PM   #10
Branman1971
Thanks speed demon. I have seen conflicting reports. I should have it licked tonight!
1961 C10 SWB
1965 C10 LWB BBW
Old 05-09-2014, 05:18 PM   #11
63burban
Chevy addict
Attachment 1251835
Would like to see better pics of your set up. Thanks
63burban is offline   Reply With Quote
Old 05-09-2014, 06:03 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I've been a beta tester on a couple projects for Captain.
I put together his template for his power steering bracket.
I now have my 65 back that I put on a 62 frame. I want to help him get one for the 60-62's made.
66 C20 Service Truck:
Old 05-09-2014, 06:31 PM   #13
speeddemon6269
I can take more pictures in the morning. Just steering gear?
Old 05-09-2014, 08:59 PM   #14
Branman1971
Hey 61K10, my frame measures about 2 3/8". Curious why you ask?
1961 C10 SWB
1965 C10 LWB BBW
Old 05-10-2014, 11:58 AM   #15
61K10
61K10's Avatar
just comparing the 2 frames, mine is wider than yours. capt-plate fit mine even though it was for a 2wd. looks like you have it figured out. somebody on here always has the info. happy steering---------
1961 chevy K10
