05-08-2014, 11:50 PM | #1 |
WTT 3/4 ton booster for 1/2 ton
I have a 3/4 ton booster on my truck, and my master hits the alternator. I need a 1/2 ton booster which is a bit shorter than the 3/4 ton to make it all fit. I just had the booster blasted, and painted it. I'd like to find one in the same condition, if anyone wants to trade. I only need the booster, not the brackets. Below is what I have and what I need, you can tell they're quite a bit different in length.
Thanks! |
05-09-2014, 07:04 AM | #2 |
Re: WTT 3/4 ton booster for 1/2 ton
I have changed many 1/2 ton to 3/4 ton booster, as they are far superior.
I think you have they wrong style master cylinder that is two long. The pics are of a NOS MC which is 8" from mounting surface to front. My 72 BB has 1" of clearance at the alternator. Hope this info helps! Thanks, Dan |
05-09-2014, 07:57 PM | #3 |
The master clears just barely, but the brake line for the rears hits the alternator. It's just the way the Inline tube conversion is set up. The master I have isn't that long, I'll have to measure but I doubt it's much longer than yours. I may just bite the bullet and grab a new delco one from Autozone if no one wants to swap. Gotta have brakes right?
05-09-2014, 08:12 PM | #4 |
Member #1049
Unfortunately its not as easy as just changing the booster as the 1/2 ton booster uses a different master cylinder and brackets than the 3/4 ton.
In fact if you pull your master cylinder off of your current booster I suspect you may find your master cylinder has the recessed hole in the piston and the rod in your booster will not reach. Here is a write up I did a few years ago that may help you out a bit. http://67-72chevytrucks.com/vboard/s...d.php?t=214559 |
05-09-2014, 08:27 PM | #5 | |
05-09-2014, 08:59 PM | #6 |
Member #1049
If your master cylinder is for 1/2 ton it definitely will not work with your booster.
You will need a booster AND brackets off any 67-72 1/2 ton. Or if you would like to upgrade to a little better stopping power, get a dual diaphram booster and brackets off of a 67-70 3/4 ton like the one pictured on my wife's Blazer. (the booster you have is off of a 71-72 disc brake 3/4 ton and is different from the 67-70 3/4 ton drum brake system) Last edited by Livrat; 05-09-2014 at 09:07 PM. |
05-09-2014, 09:04 PM | #7 | |
OK... anyone happen to have the correct booster / brackets for sale? |
