blazer tanks ?s
do 73+ blazer tanks fit under a pick-up bed without any problems? if they do how are they typically mounted? and anyone have pics of where they put their fillers? i plan on tearing down my interior this weekend to install sound deadener and i might as well get the tank out of there while the interior is stripped
Mike
The 69-72 blazer tanks will fit with some trimming of the rear cross member.I think the 73 and up are larger tanks.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
People have fit the 73+ tanks into the frame, but you have to cut out the rear most crossmember and fabricate up another one that extends out and gives room.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
