Front springs after LS swap?
I have a '72 3/4 ton C20 that I swapped the original 402 big block in favor of an LS6. After taking all that weight off the nose, it now sits pretty nose high in the front. Would I be better cutting a coil off the original big block springs, or replacing them with the small block springs from the C10? Some may disagree with me, but I personally preferred the slightly nose low rake of the original truck.
Thanks! |
Fabricate till you "puke"
Re: Front springs after LS swap?
I like a nose down rake also
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
meowMEOWmeowMEOW
ls's are even lighter still; the sbc springs are your best bet. Cut BB springs will still be stiffer and probably bouncy, plus you change the spring rate when you heat/cut them. Springs are cheap, you can find some used sbc springs easy, or go right ahead and order some nice aftermarket springs.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Cut is ok on a spring,if done properly...(figure no more that 1 full ring, if you want it to ride). Heated is a BIG NO- NO, on a spring! Some will say do not use a torch to cut....I tossed mine upside down, in a 5 gallon bucket of water. Just left the last 1" exposed, for cutting? Longhorn
man i will never cut a spring again. makes the ride so harsh.
springs are cheap. I figure my time is worth about $50/hr and hour to pull em another hour to cut em another to bolt em back in im money ahead just buying em like i want em and if i change my mind there's always someone to buy em |
yea, for the price, Ill probably go ahead and swap in the small block springs in the front and see how she looks/rides and go from there
![]() Join Date: Apr 2005
Cutting one complete coil gives you approximately 2" worth of drop. It's worth it just to see what it gives you.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#8 | |
the ride quality issue is why Im leaning towards the small block 1/2 ton spring from the C10
I think that you are looking at the situation properly
![]() Join Date: Dec 2012
I dropped my truck before the all aluminum ls swap. After it raised the truck front about 1 inch. I plan to put 1" lower springs to put it back to before ls stance.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
