new brakes
i have a brand new set of brakes for a 96 camaro. will they fit on a 71 C10 if i move everything over to it? the only thing would be mounting the calliper to the spindle. i think everything else should fit seeing how its just disk brakes. might have to change the hub out to. the truck has 18" wheels on it
Jared 2014 Ram 2500 powerwagon 2006 GSXR 600 2012 Arcticcat proclimb 800 1970 C10 SWB 5.3LS turbo and 4L60E ![]() ![]() "all throttle no bottle" "Nitrous is like a hot chick with an STD, you wana hit it but afraid of the consequences" "its not turbo lag, its for play" |
Re: new brakes
I can't say for certain, but I don't believe this is a direct cross-over. The truck brakes are more heavy duty than the cars are/were. I also think the rotors are different sizes, etc...
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
Re: new brakes
Rotors are different depth, Calipers are different, spindles? I don't what you might encounter there.
When I did my disc brake 5 lug conversion up front, car calipers (Chevelle wouldn't work) and even using a 1974 Chevy 1/2 ton there were two different Rotor Calipers set-ups, One has 1" thick rotors, then there was a "Heavy Duty" 1.25" rotor. Trial & Error can get trouble-some and expensive
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
Re: new brakes
ok thanks guys. i just had the parts laying around so i figured i would check. there super good stuff so its not lack of brakes just the fit i was conceded with.
