Old 05-10-2014, 10:41 PM   #1
Tumbleweed
PO painted over SPID. Ideas?
PO painted over the SPID on my Blazer. Anybody ever successfully overcome this? Any tricks to carefully remove paint without trashing the SPID?
Tumbleweed is offline   Reply With Quote
Old 05-11-2014, 12:39 AM   #2
SS Tim
SS Tim's Avatar
Re: PO painted over SPID. Ideas?
Depends a lot on how well covered it is and with what. Sometimes you can clean it a enough to duplicate it. Try posting a picture up so we can see it.
SS Tim is offline   Reply With Quote
Old 05-11-2014, 12:51 AM   #3
leddzepp
Moderator
leddzepp's Avatar
If it has the Mylar (clear) sheet over it lacquer thinner will remove the paint easily. If not member Chipflyer can make you a new one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-11-2014, 04:24 PM   #4
bowhunter65
acetone.
bowhunter65 is offline   Reply With Quote
Old 05-11-2014, 04:41 PM   #5
Sklptrljay
Sklptrljay's Avatar
Bowhunter is right, acetone. Just use small amounts.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 05-11-2014, 05:03 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I have done this many times successfully with lacquer thinner as well.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-11-2014, 07:21 PM   #7
72 tigger
72 tigger's Avatar
I've used lacquer thinner as well
72 tigger is offline   Reply With Quote
Old 05-13-2014, 09:31 PM   #8
Tumbleweed1C4
Tumbleweed1C4's Avatar
Thanks guys, it worked. Used acetone, didn't try lacquer thinner. Not done yet, bad part is looks like at some point somebody worked hard at trying to scrape it off, but I am able to decipher most of it. Orange was easy, burgundy, somebody put that paint on to stay, she is originally Ochre with a black top! Going to post it over in the blazer section for comments and help.
Sleep safe in your beds because rough men stand ready in the night to visit violence on those who would do you harm
72 K5 Blazer
72 K10 SWB (in pieces under slow construction!)
72 K20
Tumbleweed1C4 is offline   Reply With Quote
Old 05-14-2014, 11:46 AM   #9
bollybib
bollybib's Avatar
Considering what you were dealing with, that came out pretty good.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 06-01-2014, 11:27 AM   #10
clang6
Attachment 1253590
Attachment 1253591
Attachment 1253592
Did you just rub the SPID with the Acetone until it came off? Or am I missing a step?
~Thanks
clang6 is offline   Reply With Quote
Old 06-02-2014, 05:55 PM   #11
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
You are lucky to get that far. My '69 doesn't have the mylar film and it was painted over. Gone forever I'm afraid. I can't figure out a way to get it down to where I can make out even a portion of the lettering.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 06-03-2014, 08:56 PM   #12
Tumbleweed1C4
No mylar film on mine either. Yes, I just went at it real easy swiping at it and changing the rag when it got dirty. I feel like it got clearer after I got it close and stopped wiping. Those labels are pretty tough apparently. Too bad they scraped some away at some point with a screwdriver or something. And cut off the edge of my glove box door to make room for a rollbar. Idiots.
72 K5 Blazer
72 K20
Old 06-04-2014, 12:01 AM   #13
In The Ten Ring
Guys "bubbadize" their guns pretty badly, turning a pristine surplus rifle into a sporter that ends up being worth next to nothing and not very good for hunting.
The same appears to happen to these trucks. Each time I read on here how a lwb is cut down to be a swb I cringe. Yes, it's the owner's right and God bless him but that's one more lwb gone.
In The Ten Ring is offline   Reply With Quote
