05-11-2014, 07:19 AM | #1 |
1956 dash gauges voltmeter?
Has anyone converted a standard TF dash to house a volt meter?
I'm not really sure I need an ammeter but can see some value in a volt meter. Can I replace the ammeter with a voltmeter (obviously need some different graphics as well) ?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
05-11-2014, 07:38 AM | #2 |
Re: 1956 dash gauges voltmeter?
Do a search believe it was ogre that did 1 with a $10 AutoZone gauge
05-11-2014, 07:39 AM | #3 |
Looks pretty good to use the stock face
05-11-2014, 10:54 PM | #4 |
look in my build, i did a write up on converting a 2'' volt gauge into the stock cluster
i kept the stock face and needle. bent the needle to be in the center at 13 volts if you like what i did post up a comment to move my build from page 10 oblivion
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-12-2014, 05:32 AM | #5 |
Thanks I'll check it out
