Old 05-11-2014, 09:00 AM   #1
Mr Handy
Mr Handy's Avatar
Show me your plug wire routing!
I am working on my Jegs 350 and it is coming along really well. I am to the point that I am ready to route the wires and cut them to length... I am just trying to decide how I am going to route them and figure out what loom/separators I want to use to keep them neat and away from the headers. what have you guys found that look good and work well. I am debating between some moroso separators that attach at the valve cover bolts, and a set that would run them under the headers in more of a stock configuration...
Here is the engine as it sits minus the harmonic balancer that I installed last night.
Mr Handy is offline   Reply With Quote
Old 05-11-2014, 09:06 AM   #2
69chevytrucker
69chevytrucker's Avatar
Re: Show me your plug wire routing!
i use little zip ties i loop one tie around 4 wires then loop a tie between each around the first zip tie makes them all flat and in a row i will take a pic later today its cheap and easy and you can make it look really nice and neat
69chevytrucker is offline   Reply With Quote
Old 05-11-2014, 09:10 AM   #3
69chevytrucker
http://www.youtube.com/watch?feature...&v=Fll_OPtYsJE
here is a video of it being doen if vid doesnt work just google zip tie spark plug wire
Old 05-11-2014, 09:11 AM   #4
vidman
vidman's Avatar
I know its not a SB but here is how I ran mine.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 05-11-2014, 07:29 PM   #5
Fitz
Mine's not a small block, either!
Fitz is offline   Reply With Quote
Old 05-12-2014, 12:09 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-12-2014, 08:02 AM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Engine looks great Andy!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-12-2014, 04:31 PM   #8
bruceman1968
bruceman1968's Avatar
Awesome looking motor Andy! When are you going to drop it in?
On the wires, I like the drop from top style, but with the looms today, you can't go wrong either way.
bruceman1968 is offline   Reply With Quote
Old 05-12-2014, 05:00 PM   #9
Mator
Mator's Avatar
Not much but here is a picture of what I went with. I hope it helps.
Mator is offline   Reply With Quote
Old 05-12-2014, 07:23 PM   #10
Mr Handy
Mr Handy's Avatar
Not going in for at least a month... Nicole and I are working on getting a new place and we will need the truck to move... believe it or not but I just might get to live in a fire house, I am working hard on making that happen, calling in all the help and friends I can get, but it looks promising.
when I pull the motor I am going to get rid of the heater box and paint the firewall, frame inner fenders, and otherwise get everything real nice, then put the motor in, I expect it will take at least a few weekends to get it all done. not to mention getting the new exhaust in... I will have the bed off for that and will most likely clean up and paint the back half of the frame as well...
Old 05-13-2014, 12:20 AM   #11
67ctener
67ctener's Avatar
Billet specialties loom
67ctener is offline   Reply With Quote
