Old 05-11-2014, 10:57 PM   #1
steveo3318
steveo3318's Avatar
Where should my Temp gauge ride with 180 stat
Ok so I bought the truck and the temp gauge would barely register cool. Found the truck had a 160 stat in it! Well I stuck a 180 in and now it reads barely above the first notch at times and on the notch most times. Kind of fluctuates, My temp shooter gun says its 180 to 185 all over the block. It has what looks to be a factory flex fan! I just ordered a new 53-811 sending unit but have the question of what sealant to use or none?
At 180 where should my gauge ride? And is it usual for these truck factory gauges to move pretty quick under normal stop and go driving conditions? "Like from a needles width above the first line to below it after a good take off and good radiator airflow?
thanks gents ahead of time.
steveo3318 is offline   Reply With Quote
Old 05-12-2014, 01:07 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Where should my Temp gauge ride with 180 stat
I run a 160° in mine and it rides right on the first line above "cold", whether it's 110° out or 40°. You may have the wrong sending unit in there. When you install the new one, I'd just use thread seal tape.
69GMCLonghorn is offline   Reply With Quote
Old 05-12-2014, 04:00 PM   #3
jborders
jborders's Avatar
It's been a while since mine had the factory gauge but I'm thinking it stayed toward the cooler side with a 180 thermostat but the actual temp was always 185ish. You can use thread tape but don't use too much the sender gets it's ground through its housing .
jborders is offline   Reply With Quote
