Old 05-12-2014, 08:41 AM   #1
73737373
Starter Will Not Engage
72 1/2 ton, big block. Been parked for several years. Put a new battery in and turned the key, but no starter action..nothing. There's power to the ignition system when the key is in the run position. I'm thinking neutral safety switch. Had an old 72 Cadillac that did the same thing. Thoughts?
And yes, before I tried to start the engoine, I made sure that it spun and pulled the plugs and squirted some lubricant in the cylinders.
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 05-12-2014, 11:00 AM   #2
airdale94
airdale94's Avatar
Re: Starter Will Not Engage
See if you have power at the purple wire on the starter solenoid while cranking. If not it's farther back.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
