Old 05-12-2014, 12:52 PM   #1
jcblue
jcblue's Avatar
Serpentine setup from junk yard
What is out there that I can use on my truck for a serpentine set up? I have a long water pump and power steering. Also have a vintage air.. Will an 88 cheverolet truck work?
jcblue is offline   Reply With Quote
Old 05-12-2014, 01:04 PM   #2
MARKDTN
Re: Serpentine setup from junk yard
Yes, 88-95 truck. Be aware that your A/C header pipe will probably not work since it moves the compressor back.
If you can get a whole setup- Van, Camaro, and Caprice work too. Corvette will work, but with the aluminum water pump you have to use an electric fan. IMHO don't bother with the CS130 alternator, do a CS144 swap while you are doing it.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-12-2014, 01:14 PM   #3
truckdude239
truckdude239's Avatar
also 97-99 4.3-350 will bolt up just changes the places of everything
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-12-2014, 01:35 PM   #4
A8Jamesa8
I'm interested in doing this swap aswell, do you still need a reverse rotation water pump if you go with the 88-95 truck surpentine set up??
A8Jamesa8 is offline   Reply With Quote
Old 05-12-2014, 01:52 PM   #5
MARKDTN
Yes, you should use the correct water pump for the donor.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 05-12-2014, 02:15 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Avoid 88-89 model set ups. They used steel brackets which were very prone to breaking and cracking. Aluminum ones started in 1990 and had none of the problems that the steel ones did.
Old 05-12-2014, 03:10 PM   #7
Lee H
Lee H's Avatar
Keep in mind that the brackets are different between the years. Best bet to get all the brackets, accessories, and fasteners off the same donor. Then as parts (water pump, PS pump, drive belt, idler pulley, alternator, etc) are needed get the replacement part for that donor. Nice thing about a truck donor is that the AC compressor is on the passengers side and the alternator is on the drivers side. A few years ago Car Craft did a very good article on this swap and it's still on their web site.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-12-2014, 03:37 PM   #8
bonnieclyde100
all this depends on your cylinder heads and weather or not they have accessory holes on each end some dont
bonnieclyde100 is offline   Reply With Quote
