![]() Join Date: Apr 2013
converting SM465 to M22/21/20 T-10
Looking to convert my 71 SWB Stepper from an SM465 to an M-22/21/20 or T-10. New motor going in and was wondering about the hump and the driveline mostly. I could figure out the rest.
Re: converting SM465 to M22/21/20 T-10
Not sure on the hump, but the trans. x-member and driveshaft should be stock TH350 configuration.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
![]() Join Date: Jan 2002
If its a factory 4 speed the hump is removable. U could weld in a patch and cut your hole for your shifter after u mount tranny. Or you could find a big block auto hump which wouldn't have a hole from the factory then you could just cut the one hole you need.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Check the coller on the trans you are using. The SM465 has a larger hole in the bell housing then some of the other transmissions.
