Robert Olson Transport
![]() Join Date: Oct 2002
What the heck is this?
this has two air lines to it and it goes in between the two sections of the upper hose on the 427?
truck overheated majorly found a pin hole in the heater hose between the block and rad... the hoses here were leaking a little... just trying to figure out what this is going to cost me
Re: What the heck is this?
It's and oil cooler. They are supposed to go in the lower hose though.
OPPS, I was going by the picture only. Don't know about air lines
65 C20 292 4spd 4:56 Eaton HO52 Last edited by Fatherof3; 05-12-2014 at 05:57 PM. |
and a few others
Interesting. Just a wild guess here from an ex-truck driver:
Could that be an air heater of some kind? The modern air dryers have only been around for about 40 years, so this may be what pre-dated the air dryer. If that's what it is, it would be there to keep the moisture in the air brakes from freezing in winter. Like I said, just a wild guess.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Sad thing is none of the guys at Napa know either lol
That's an engine cooler that uses water from the fire pump to cool the engine down if it overheats while pumping water. There is a coil of copper tubing inside, it circulates the water back and forth from the pump. My '69 GMC has one, the copper lines run to a small gate valve near the pump.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
that makes sense.. im going to bypass that for the moment to see if there is any damages to the motor after overheating. Ihave since found the radiator to be leaking
