Old 05-13-2014, 12:58 PM   #1
pimpston65
pimpston65's Avatar
inline 6 vs. 283
so after decoding my new 66 suburban 4x4 (6K1406626910A)i find it came with an inline 6. how would i find which 6 it would have come with? it has a 283ci in it now , but seller says its from a pontiac. i also was reading that a 283 could have been an upgrade. my question. since the numbers for torque and hp are really close would i have a more powerful engine with the 6 in weight savings? does it weight less? and what about fuel savings? i also wanna run ac and stock radio and use the cig outlet for a converter to run a ipod or small bose system on our road trips. if i get the 6 should i just upgrade the charging system? i need help, but on the carryall for now!!!
pimpston65 is offline   Reply With Quote
Old 05-13-2014, 01:34 PM   #2
ChuckW
ChuckW's Avatar
Re: inline 6 vs. 283
IMHO I'd stick with the V8. Think you'll find it to be better overall as far as power and torque. Though I know die-hard I 6er's may feel otherwise
ChuckW is offline   Reply With Quote
Old 05-13-2014, 02:31 PM   #3
Lugnutz65
Lugnutz65's Avatar
The inline 6 is heavier than a 283ci or even a 350ci. I don't have any figures to back that up, but I think it's a LOT heavier than any SBC.
I have no experience driving either one.
The L6 (230, 250, 292) is going to be unique when you pop the hood. A nice conversation piece. The SBC is less unique but upgrades and add-ons are very plentiful and cheap.
For example, I will need to spend a LOT of money to get power steering pump brackets for my 250ci L6. The brackets for a SBC are so plentiful and cheap that you would have several to chose from at the local salvage yard.
If you are planning A/C and PS and other upgrades, then the 283ci would be the easiest and cheapest route to take.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-13-2014, 02:51 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Nope, this generation of inline 6's (194, 230, 250, 292) are all lighter then a SBC. The previous generations were heavier.
Dollar for dollar, you cannot go better then a SBC. Parts are very easy and cheap to buy. In a heavy, aerodynamically challenged truck, MPG from an inline 6 or a mild 283 (or likely most any SBC) is going to be very close.
If you already had a well running I-6, I would leave it and be happy. If you already have a SBC that runs well, I would leave it and be happy. If you want to swap for the cool factor, the I-6 is the way to go. If you want to swap for better power or cheaper to build, SBC hands down.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-13-2014, 03:20 PM   #5
1963c-10
1963c-10's Avatar
194-250 weighs around 450lbs......would think a 292 would be 50-75lbs more
216-235 weighs around 630lbs
sbc iron heads/intake around 575lbs
bbc iron heads/intake around 685lbs
Also....as I just found out recently when picking it up....the 348 "w" engines weigh 650lbs.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-13-2014, 03:27 PM   #6
Lugnutz65
Lugnutz65's Avatar
Well, I stand corrected and thanks for that. I'd hate to keep telling people something that just ain't true. I am surprised and happy about the news all at the same time. Now I'd be a lot happier if I could just find some PS pump brackets for my L6!
Old 05-13-2014, 03:40 PM   #7
pimpston65
pimpston65's Avatar
thks for all the info, once i get my mitts on it and drive around a bit. i will make a choice on 6 or keep the 8. ima kinda leaning towards the 6 and the original equipment aspect my 65 C10 has a 283 and wanted to have twins but i think i need the challege of finding and building the 6. i sure i will come up with something, ps this forum rocks. also will the 6 (292) mate up to the 4speed thats in it? im assuming it will but not sure i dont want to go making adaptor plates and/or changing to much... thks for all the info
Old 05-13-2014, 04:41 PM   #8
1963c-10
1963c-10's Avatar
No problem....and you were pretty close. The older gen L6 were quite a bit heavier.
And PM sent on p/s brackets
Old 05-13-2014, 07:27 PM   #9
65chevysub
65chevysub's Avatar
My 65 originally came with a 292, and a Powerglide. The 292 was optional, if I remember correctly. I sure wish I had it back in my truck. I used to have a 65 Chevy II Nova 4 door that had the 194 in it, and it could outrun just about anything on the road, and it even had the 3 on the tree. I love inlines.
65chevysub is offline   Reply With Quote
Old 05-13-2014, 07:43 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
The 292 will bolt up, but as far as I know a stock 292 uses an 11 inch clutch and a stock 283 came with a 10 inch...don't know if it matters if the bell housing hooks. But a 292 will do better on power then a 283.
283 HP 145 @ 4400 rpm Torque 260 at 2000-2500.
292 HP 153 @ 3600 rpm Torque 275 at 1600-2000.
Though I think something was wrong with that cause I got my mostly stock 48 year old 292 to do 4900 rpm...lol Mileage on the 292 will be around 13-15 on highway driving at 2500.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-13-2014, 07:58 PM   #11
pimpston65
pimpston65's Avatar
yeah i need all the mpg i could get. i plan on using it for trips to Pa. and back twice a month also... what yrs were the made cuz i saw a 81 from a C10. but looked simular on CL.
Old 05-13-2014, 09:43 PM   #12
Irishbleueyes
Inline 6 is vintage all the way cool. I have a 283 I use for work everyday and with the bed full of tools about 800lbs worth gives me about 13.5 mpg around town. The 283 does barley produces the torque to haul the heavy load (but does). To battle i have installed HEI with MSD 6al, headers with duals all the way out the back and new 500 cfm Edelbrock carb fully calibrated with AFR (air fuel ratio) gauge installed in the truck keeping the AFR above 15:1 on the primaries around town. HWY mpg is really good, 18 and above and thats with 3:73 rearend.
The inline 6 gets my vote bro!
Irishbleueyes is offline   Reply With Quote
Old 05-14-2014, 08:35 AM   #13
morethanstock66
morethanstock66's Avatar
+1 on the I6 idea. I had a 250/sm420 with 4.56s in my 67 for 5 year. Great engine with torque and gas. I swapped to a crate 350/sm420 with 3.73s for the last couple years and mpg went down. I6 is a really cool piece and definitely a conversation starter. I love the sbc, but the I6 was interesting. Plus, if you want you can bump up performance later on with Clifford, Offenhauser, ect. later on. I6s have a cult following though- you'll definitely find new friends with it. Just my .02
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 05-14-2014, 09:15 AM   #14
63burban
Chevy addict
If you are going to use it on trips, I would use a 305 with stock heads, RV cam, small Edelbrock carb, hei ignition, 2" exhaust. 700r4 trans with 3:55 or 3:42 rear end gears. I have set up this combination in several vehicles and have very good luck with power and mileage. In my 56 Chevy Belair I am getting 22mpg at 70mph on the hwy, my 63 Chevy C10 shortbox is getting 18mpg at 70mph on the hwy. All the power and torque you need.
If you are running around locally, a six and three speed is great and a lot of fun, or a six and turbo 200 trans. Just my experience.
63burban is offline   Reply With Quote
Old 05-14-2014, 09:20 AM   #15
MikeN
MikeN's Avatar
Pontiac never made a 283, and no Pontiac I'm aware of was ever fitted with a Chevy 283.
MikeN is offline   Reply With Quote
Old 05-14-2014, 10:54 AM   #16
pimpston65
pimpston65's Avatar
i will be checking for sure, its got chevorlet script rocker covers if that shows anything, but im only going off pics. the only reason i said pontiac cuz thats what the seller stated i hope its a 283 cuz it will be better to trade maybe or sell then get the I6. i just want to tear into this beast NOW but gotta wait til i take delivery. guess all i can do is educate myself and dream, i should have it in 2 weeks
Old 05-14-2014, 11:15 AM   #17
1963c-10
1963c-10's Avatar
There were a number of early Pontiacs that used the 283. All I know of were Canadian production....not sure if Chevy or Pontiac built the engines, but they were called Pontiac 283's Superflames or Econo Superflames....
Couple of pics of OEM Pontiac engines
Good thread on Canadian 283 cars/engines http://canadianponcho.activeboard.co...iacs-1955-197/
They also used the 348, 396, 409, 427 and 454 big blocks and most of the inline 6 engines.
Old 05-14-2014, 11:53 AM   #18
rideblue00
rideblue00's Avatar
thats news to me...never seen a pontiac that looked like a sbc!
rideblue00 is offline   Reply With Quote
Old 05-14-2014, 11:56 AM   #19
1963c-10
1963c-10's Avatar
Seems they were even orange when 1st produced
Old 05-14-2014, 12:00 PM   #20
pimpston65
pimpston65's Avatar
well the truck is in canada, i wonder if it was sent there str. from the factory or is it a transplant? then again why put a pontiac engine in a chevy. im sure they just throw whatever engine was around and fit. at leasts its GM
Old 05-14-2014, 12:02 PM   #21
Old Truck Man
Old Truck Man's Avatar
Yes Pontiac cars sold in Canada had Chevrolet engines including the 283. and they said Pontiac on the valve covers. Not to be confused with the Pontiac 287 engine. I own a 55 GMC with a 287 Pontiac engine factory installed.
Old Truck Man is offline   Reply With Quote
Old 05-14-2014, 01:26 PM   #22
MikeN
MikeN's Avatar
That's my point, a Pontiac 283 is really a Chevy.
Old 05-14-2014, 01:45 PM   #23
pimpston65
pimpston65's Avatar
cool at least i got that cleared up
Old 05-14-2014, 04:06 PM   #24
Old Truck Man
Ok and a 403 Pontiac engine in a trans am os really a oldsmobile engine. However the 335 GMC v8 used in59 was a Pontiac design however it was never installed in Pontiac cars only in GMC trucks. Its likely the Chevrolet 283 used in the Pontiac cars was different than the 283 used in Chevrolet,s. It could have different type pistons or internal parts. A example the 292 ford engine used in59 the car engine had a cast crank . The truck engine had a steel crank and different length rods and different piston pin height.
Old 05-14-2014, 08:09 PM   #25
1963chevyc20
1963chevyc20's Avatar
i would stick with the 283! i own one and i love it! http://s1357.photobucket.com/user/Ar...llson/library/
1963chevyc20 is offline   Reply With Quote
