Old 05-13-2014, 09:55 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Heater blows cool - what else on the checklist?
The underdash guts of my 72 Blazer with A/C are exposed as I added an am/fm radio recently and need to replace a leaking heater core. This winter I had lukewarm air blowing from the vents and want to fix this problem when I replace the heater core. So far here's what I've checked to trouble shoot the lack of hot air:
- coolant level is fine
- have hot coolant flowing to the heater core past the heater control valve
- vacuum lines seem routed appropriately with no apparent leak
- A/C control lines seem appropriately routed
I'm concerned about some broken/stuck flapper valve or bad vacuum actuator somewhere. Which of these duct work components should I inspect? Should there be a noticeable vacuum coming from the vac ball affixed to the A/C condenser box on the firewall with the K5 running?
I'd appreciate any and all suggestions.
Thanks, Pete
Old 05-13-2014, 10:08 PM   #2
67chevy1
67chevy1's Avatar
Re: Heater blows cool - what else on the checklist?
The heater core wouldn't be about half plugged would it?
67chevy1 is offline   Reply With Quote
Old 05-13-2014, 10:23 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Haven't torn into it yet - it's possible for sure. I'm trying to come up with any other possibilities to check in case the core isn't the problem. I want to fix it the first time and quickly so I can drive the roads in Glacier Park now that spring is here - with the top off the Blazer I may need a working heater up on Logan Pass!
Old 05-14-2014, 05:10 AM   #4
SS Tim
SS Tim's Avatar
I'd start with a factory manual review then a vacuum check. Use a hand pump and check your actuators and switches. The ball (reservoir) just stores vacuum but it would be worth leak checking. Cap the ports and pull a vacuum on it.
Might consider a set of seat heaters they can make a world of difference.
SS Tim is offline   Reply With Quote
Old 05-14-2014, 08:27 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Tim - good suggestions!
