Old 05-14-2014, 09:54 AM   #1
terbronco7
terbronco7's Avatar
Fuel Gauge hook up
Got some new factory replacements and need to know how to wire the fuel gauge, I have a wire coming from the sending unit (thats it have no clue as to where to go from there). Bought truck like this and I need some help) Ran out of gas twice now)....230 with granny 4 is terrible on gas......
terbronco7 is offline   Reply With Quote
Old 05-14-2014, 10:12 AM   #2
1963c-10
1963c-10's Avatar
Re: Fuel Gauge hook up
this should help.
Your sending unit wire will go the fuse box. On the back of the gauge.....pink on the right and tan on the left side of the gauge as your looking at the back of the cluster.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-14-2014, 10:35 AM   #3
terbronco7
terbronco7's Avatar
Originally Posted by 1963c-10 View Post
this should help.
Thanks so much this helps alot.
Old 05-14-2014, 11:27 AM   #4
1963c-10
1963c-10's Avatar
No problem.....
Old 05-15-2014, 10:29 AM   #5
1963chevyc20
1963chevyc20's Avatar
mine is hooked up but it says i have a full tank when i only have a third of a tank? it use to not do that!!
1963chevyc20 is offline   Reply With Quote
Old 05-15-2014, 08:19 PM   #6
ray_mcavoy
Some common causes for the gauge to read full (or over-full) are:
(1) Bad connection or broken wire somewhere between the gauge and sending unit. A quick way to test for this is to temporarily jumper the sending unit wire to ground. If that makes the gauge go to empty the wiring is okay. If not, check for bad connections or a break in the sending unit wire.
(2) Poor ground connection at the sending unit. Check to make sure the ground wire has a good clean connection that's free of rust & paint build-up.
(3) Failed sending unit.
ray_mcavoy is offline   Reply With Quote
Old 10-21-2014, 01:51 PM   #7
61K10
61K10's Avatar
my gauge stock with new sending unit, the needle just barely moves from where you can't see it to just past empty toward the full side. the new sending unit ck ok with meter at 0-30 om. bad gauge? wires reversed on gauge?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-21-2014, 02:08 PM   #8
blown240
blown240's Avatar
What happens when you ground the wire to the sending unit?
And what happens when you pull that wire off the sending unit?
blown240 is offline   Reply With Quote
Old 10-22-2014, 01:40 PM   #9
61K10
61K10's Avatar
I replaced the gauge with one that came with the tk and it was working. still doesn't work. will do some more testing today.
1961 chevy K10
Old 10-22-2014, 02:24 PM   #10
Micmac
Micmac's Avatar
Thanks for the diagram, mine bounces like a kangaroo on amphetamines! I used to live in Fayetteville, on Gruber Road!
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
