05-14-2014, 12:09 PM | #1 |
door panel issue
I cant get the panel off the inside of the drivers side door. How do I get the window crank and door crank off so I can get the panel off to fix the door opener? Included pics.
thanks, paul |
05-14-2014, 12:27 PM | #2 |
Re: door panel issue
push the panel back enough to look in agap behind the handles, there will be a little U clip you need a scribe or a ice pick to push it off the groove, or you can buy a small tool to remove the clips
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-14-2014, 12:37 PM | #3 |
Ok thats good to know. Thanks. Do I remove those drak brown gaskets first to get the tool in there? Looks to me like I must first remove those. And its not obvious how to do that either.
thank you, paul |
05-14-2014, 12:43 PM | #4 |
no you have to open a gap, just so a little push and pull
05-14-2014, 12:45 PM | #5 |
when you put the handles back on put the clip in the groove of the handle first then pop the whole assembly on with the palm of your hand
05-14-2014, 02:12 PM | #6 |
Getting the tool is well worth the $5 or so - all the truck parts suppliers have them, here is one on Amazon so you can see what they look like:
Amazon.com: CRL Door Handle and Window Crank... Makes the job a lot easier both on and off. |
05-14-2014, 04:34 PM | #7 |
I made a "tool" by taking one of the metal strips that are along the sides of some wiper blades and bending a short hook at the end (about 1/8" and slightly more than 90 degrees). Just insert it through the loop at the end of the clip and pull. Works better for me than that tool shown above.
05-14-2014, 04:37 PM | #8 |
or a strong piece of wire with a loop in it
05-14-2014, 04:40 PM | #9 |
I got one off once with a screwdriver, a BFH and a lot of cussing.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
05-14-2014, 04:55 PM | #10 |
05-14-2014, 07:44 PM | #11 |
To remove the handles just wrap a shop rag around the part with the clip
then pull one end of the rag Have it on a clean surface cause the sping will jump to who knows where.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
05-14-2014, 11:39 PM | #12 |
Skip all this hassle... Take a thin cloth or old shirt, insert behind the handle, make a full circle and the clip will be in the rag. Works EVERY time
05-14-2014, 11:43 PM | #13 |
The $5 tool is available at ANY parts store and fits tons of cars and trucks.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-15-2014, 12:48 AM | #14 |
Thanks to all for the responses. Im overwhelmed with options. You guys are the best!
All of you were also indispensable when I needed info on installing a trailer brake controller. One post pointed out exactly the correct wire to tap into for the brake signal. paul |
05-15-2014, 11:45 AM | #15 |
I always use a butter knife.
I'm not as good as I once was, But I'm as good once as I ever was. |
