Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-14-2014, 12:52 PM   #1
cst350
cst350's Avatar
Question Relay Wiring for Dummies like me
Ok, I want to wire a kill switch to my distributor. I want to use a small switch so I need to use a relay. I go online to search for relay wiring and I get so many options I don't know which one will work. I need to know what numbers should go to:
Wire from ignition (That I will cut)
Wire going to distributor (other end of wire I will cut)
Power for the relay (12 volt from fuse block)
Ground (putting kill switch from here to chassis ground)
I think it goes as follows:
86-Wire from ignition (That I will cut)
87-Wire going to distributor (other end of wire I will cut)
30-Power for the relay (12 volt from fuse block)
85-Ground (putting kill switch from here to chassis ground)
Also, should my 12 volt from fuse block be a certain fuse size? Do I go for 12 volt constant, ignition or Accessory?
Any help or comments appreciated!!!
cst350 is offline   Reply With Quote
kill switch, relay
