05-14-2014, 08:33 PM | #1 |
Junior Member
needed picture with advice
im looking for a picture of how the positive battery cable is fasten to the frame and how it is run along the frame rail.the way the factory made it for my 72 blazer 350 4x4 thank for the help, mark
05-17-2014, 07:27 PM | #2 |
Re: needed picture with advice
Not sure this is correct but this is how I did mine. Battery cable goes strait down, under radiator hose, band clamped to block ( with insulated hose ) and is woven behind motor mount to starter. similar to this Link. 67-72chevytrucks.com/vboard/showthread.php?t=524251
Last edited by notsolo; 05-18-2014 at 07:13 PM. Reason: Redone- Corrected-NO Frame attachment |
05-17-2014, 07:33 PM | #3 | |
fyi there is no electrical connection from the hot to the frame...that would be a bad thing....
Ed will be known as the Tiger Woods of the integration business |
05-18-2014, 05:05 PM | #4 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-18-2014, 07:25 PM | #5 |
I think Scott ( Thanks TURP ) has this correct on the frame attachment loose loop.
