Old 07-31-2003, 01:47 PM   #1
Ryan Flowers
No Brakes Club
Ryan Flowers's Avatar
Question 8" Lift & 3/4 Ton Axel swap - Help Needed!
Fellow gear heads,
I need help with the following:
I am going to put an 8" lift on the 90 Suburban. While I am at it I want to go ahead and drop a pair of GMC 3/4 Ton axles under it. Can anyone tell me if this is a swap and bolt project? I know I will have to have new drive shafts made but are there any hidden things I should know about, like brake cables and hoses not matching up or spring perches needing to be relocated. I will also be doing a cross over steering (thanks Pont for that recomendation). As soon as she is complete I will be posting pics. Any and all info would be GREATLY appreciated.
Thanks,
Ryan Flowers
85 GMC Suburban 4x4 379
90 GMC Suburban 4x4 383
01 Chevy Suburban 2x4 350
Click here to email me
Click here to visit my web site
Ryan Flowers is offline   Reply With Quote
Old 08-01-2003, 05:06 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
For the most part it should be bolt-on. The big stuff will. Shouldn't have to fab anything since the Suburban did come as a 3/4 ton. What rear axle will you be using? Probably a 14 bolt. The spring pads should be the same it's the 1 tons that are different width. Definetly need longer brake lines. Is it going to be an all spring lift?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-01-2003, 10:23 AM   #3
Ryan Flowers
No Brakes Club
Jim,
Yes it will be an all spring lift. Thanks for the info.
Ryan Flowers
Old 08-01-2003, 02:57 PM   #4
1FaastC10
1FaastC10's Avatar
what year are your axles? i believe 88+ had a driver's side pig, and the older ones were on teh passenger side.
1FaastC10 is offline   Reply With Quote
