05-14-2014, 09:25 PM | #1 |
Photo or diagram of 71+ disc brake master?
I've converted my '70 drum/drum Longhorn over to '72 disc/drum. All factory parts I bought from the same guy (Jesse) that I bought the truck from - they were parts he was going to install before he sold it. Which is a long way of saying I don't have any photos. And my manuals are all pre-disc.
The booster is larger, the prop valve is different, and even the brackets are a little beefier (can't help but wonder if this is maybe from a 3500, but no idea). Does anyone have a good photo of an existing factory setup, or a picture of the assembly or shop manual diagram for the factory discs? Preferably big-block 2500 or larger, but I'll take what I can get! Thanks, Dave
05-14-2014, 09:48 PM | #2 | |
Re: Photo or diagram of 71+ disc brake master?
Here's a link to a 3/4 ton booster at Rock Auto. http://www.rockauto.com/catalog/more...759&cc=1442361 Jim |
05-14-2014, 09:55 PM | #3 |
Thanks. I have all the parts (except the lines), just not sure what brackets go where and how the lines are routed.
I'm using a new master (cheap) and disc brake prop valve (expensive). No one makes a line kit either, it seems, so I might be winging it anyway.
05-14-2014, 10:09 PM | #4 |
I pulled this off my "72 Custom" parts truck with power disc/drum setup. Haven't got it installed yet.
05-14-2014, 10:21 PM | #5 |
05-14-2014, 10:22 PM | #6 |
Might try downloading a 72 manual so you have some pictures and specs. Here are a couple of pictures I dug up that might start you off.
* VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID Blazer SPID Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-14-2014, 10:25 PM | #7 |
Here's a link to the 72 manual. Try section 5. It starts on PDF page 149.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016 |
05-14-2014, 10:35 PM | #8 |
Hmmm... posted about 8 photos, all gone. Will try again!
05-14-2014, 11:06 PM | #9 |
05-15-2014, 11:54 AM | #10 | |
There is a website where a guy took several pictures and explained it.. helped a lot when I replaced my brake system. Its proving a bit difficult to find.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
05-15-2014, 01:15 PM | #11 |
Pictures of my 72 1/2 ton Cheyenne
05-15-2014, 01:34 PM | #12 |
Well, I ordered TKT7107S from Summit, we shall see.
