Old 05-14-2014, 10:52 PM   #1
69chevytrucker
69chevytrucker's Avatar
Talking gas filler hose
dumb question what is gas filler neck hose made of can you use rad hose or what i relocated my tank and i need a piece about 18 or 20 inches long to go from the tank to my filler neck just need to know what i can use thanks in advance
69chevytrucker is offline   Reply With Quote
Old 05-14-2014, 11:10 PM   #2
LSUMurse
LSUMurse's Avatar
Re: gas filler hose
I don't know the answer, but I have seen non-fuel rated hose that has come into contact with fuel, swell up. I would get a measurement and go by one of the auto parts stores and see if they have something that will work.
This site has by the inch:
http://www.fillernecksupply.com/servlet/StoreFront
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 05-14-2014, 11:47 PM   #3
71GMCEWAN
71GMCEWAN's Avatar
Re: gas filler hose
No you must use hose rated for fuel.
Otherwise the fuel vapours will deteriorate the rubber and it will come apart and get in your tank.
71 GMC LWB GMPP Fast Burn 385 crate engine, T-350, Factory A/C, tilt, gauges, buckets and console changed to houndstooth bench, 411 posi.
Click Here for pictures
71GMCEWAN is offline   Reply With Quote
Old 05-14-2014, 11:57 PM   #4
BigMike
BigMike's Avatar
Re: gas filler hose
It has to be fuel rated. I think your average fuel lines/hoses have a thread mesh embedded into the rubber to prevent it from expanding too much. Like 71GMCEWAN said, it will deteriorate and fall apart.
Also, the only dumb question is the one not asked. That question had the ability to be very dangerous had you not asked it.
Mike
BigMike is offline   Reply With Quote
Old 05-15-2014, 06:20 AM   #5
cdowns
cdowns's Avatar
Re: gas filler hose
i find that fuel hose is readily available at the local boat supply places
Old 05-15-2014, 12:29 PM   #6
69 MOD
69 MOD's Avatar
Re: gas filler hose
My local parts supply store has bulk fuel tank filler line (that's what it's called) in 2 or 3 different sizes.
You can buy it by the foot.
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 05-15-2014, 02:44 PM   #7
67 cst swb
67 cst swb's Avatar
Re: gas filler hose
This place has some fuel filler hoses
http://www.autopartsandstuff.com/sea...ates+Fuel+Fill
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-15-2014, 03:49 PM   #8
BigMike
BigMike's Avatar
Re: gas filler hose
I got a deal on mine on eBay for around $12. I have the side mount fill on my tank I bought from CPP in '06. Says "73-7p P/U Filler Neck Hose" Part #00343106
Hope that helps.
Mike
Old 05-15-2014, 04:35 PM   #9
69chevytrucker
Re: gas filler hose
Hope that helps.
Mike
sweet that one looks just like what i need
