Old 07-31-2003, 02:26 PM   #1
SweetZRag
Question Pop noise in front end?
HELP!
I have been hearing an occasional pop noise in the left front wheel area. It usually happens when backing out of my driveway with the wheels turned hard left. Sometimes it happens when I take off at a traffic light. I can feel it in the floorboard.
The blazer has 199,000 miles on it. The left front tire was worn on the outer edge in a scalloped pattern. I found the upper born joint had play so I replaced all 4 ball joints (that was fun!). I also replaced all 4 shocks.
The tie rod ends look good and so do the sway bar bushing and lower control arm bushings as far as I can see. Does anybody have any idea of what could be causing this?
I recently replaced the boot on the outer CV joint . The CV joint looked OK when inspected and I regreased it and put a new boot on. I later found the new boot wasn't clamped tight enough and so I reclamped it. Could this sound be from the CV joint going bad?
Any ideas?
1994 Blazer (Not Tahoe or S10!) Edelbrock Shorty Headers, Air Rade throttle body spacer plate, Accel Rotor, cap, MSD coil. Bosch Platinum 4 plugs, steel cowl induction hood, 360,000 miles
SweetZRag is offline   Reply With Quote
Old 07-31-2003, 07:08 PM   #2
COBALT
COBALT's Avatar
I'm not well versed on 4x4 front suspensions, but anything that gets tension/compression on it when you turn corners will be the culprit.
I had a noise like this on my 2wd C20. Turns out my lower control arm center bar had totally egged out one of the bushings. It would bang back and forth in the bushing every time I turned a corner. Sounded like a grenade going off. When I got the bar out the bushing just slipped off the bar. OOPS! Glad I checked.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-01-2003, 10:04 AM   #3
SweetZRag
Cobalt,
Thanks for the tip. I have checked the obvious and your idea is one that might help me figure this out. I am going to climb under there "one more time" on Sunday and see if I can locate the cause. I can't afford to tear the truck apart without knowing the cause because I need it to get to work.
Does any body else have any suggestions I should check?
Old 08-01-2003, 04:21 PM   #4
Krosati
If it only happens when you hit the brakes, check the calipers for slop. Push it toward the front and then to the rear. If they move, you may need to replace.
The sound may be the caliper sliding forward and hitting the spindle.
Krosati is offline   Reply With Quote
Old 08-01-2003, 04:34 PM   #5
SweetZRag
The caliper idea is an interesting one also. I will try applying the brakes to see if I can consistently recreate the noise. So far it has been a little difficult to repeat on demand. I do recall feeling a bump in the brake pedal once or twice. You may be onto something. I'll let you all know what I find when I take a deeper look on Sunday.
THanks!
Old 08-01-2003, 07:44 PM   #6
73stepside
73stepside's Avatar
on 82-92 f-bodies, the frame where the steering gear bolts to sometimes cracks and causes the popping noise
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
