Old 05-15-2014, 11:54 AM   #1
Houston Ben
Houston Ben's Avatar
Coolant??
Hey all, 2011 5.3. I have been trying to get a good answer but cant find one, what kind of coolant should I run? I have been using just water but I don't think that is a good idea. I have read good and bad about dex-cool but I don't know much about coolant.
Thanks for any help
Houston Ben is offline   Reply With Quote
Old 05-15-2014, 02:08 PM   #2
solidaxel
solidaxel's Avatar
Re: Coolant??
Chevrolet engineers made that stuff for a reason, I am sticking with what they recommend!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-15-2014, 03:38 PM   #3
First c10
First c10's Avatar
Re: Coolant??
The orange stuff here.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-15-2014, 03:49 PM   #4
bpatrol
Re: Coolant??
just run prestone. dex cool sucks. if you have more then one type of metal in the system it will gum up. do a search and judge for yourself
bpatrol is offline   Reply With Quote
Old 05-15-2014, 04:43 PM   #5
solidaxel
solidaxel's Avatar
Re: Coolant??
Factory 5.3 aluminum heads and cast iron block, factory pink, there must be more to it
LS 3 4L70E
Old 05-15-2014, 05:32 PM   #6
bpatrol
Re: Coolant??
just type in dexcool in a general search. Lots of hits and misses.
plain old green stuff? all good.
I myself had a bad experience with dexcool on a tahoo. it gummed up my heater core and found out there was a tech bulletin on dexcool. Never again
http://www.consumeraffairs.com/news0...m_dexcool.html
Old 05-15-2014, 05:46 PM   #7
crazy longhorn
Fabricate till you "puke"
Re: Coolant??
On the 5.3 swap ,in my 69 I am running the green "coolaid". as said above ,don't mix em Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-15-2014, 10:39 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Coolant??
from what I've gathered....those that had problems with dexcool were more likely to have a leak and more importantly... a low coolant level.
sealed and full systems don't generally have the same problem. My TBSS is 7-8yrs old now and still running dexcool without a problem. System was flushed early at like 25k mi. and truck has 97k now.
That said.....when I do flush it this summer it'll probably get the green stuff.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-16-2014, 12:24 AM   #9
Blackpony
Blackpony's Avatar
Re: Coolant??
I run dexcool in all my vehicles with no issues thus far
Blackpony is offline   Reply With Quote
Old 05-16-2014, 01:09 AM   #10
Andy4639
Old member
Andy4639's Avatar
Wink Re: Coolant??
I have a 08 Tahoe with it and it has 70,000 on it no problems. My wifes 2011 Treverse has it 60,000 my 71 has it in the 6.0 my son's 2014 camaro has it. It's new.
I don't see a problem with it but who knows. GM isn't recalling them for coolant yet!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-16-2014, 08:15 AM   #11
truckdude239
truckdude239's Avatar
Re: Coolant??
i used a 50/50 green mix longlife that mixxes with any color and type of coolant
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
