05-15-2014, 12:44 PM | #1 |
more issues!!
ok. now that i am forced tto work on the truck. lets get down to business. how do i replace a crank shaft seal? which pulley do i remove? will the pulley just unbolt off? it is on a 283 v8. also how would i replace the oil pan seal. motor is mounted to truck! when i change oil do i put in 5 qts? thanks! for the crank seal i already removed the fa shroud, the fan blade and truck battery. what else?
05-15-2014, 12:49 PM | #2 |
Re: more issues!!
sorry about this guys!! poor truck. how is she still chugging along?
05-15-2014, 01:30 PM | #3 |
Check The Champ, Demonstrator
Re: more issues!!
Not criticizing, but, why not buy a shop manual, original, reproduction or on CD. Most of your worries and fears will disappear. One of the first books I purchased after buying my truck. It shows step by step how to do mechanical repairs.
I'm a literature nut to an extreme and I'm always baffled to see someone buying an older vehicle and not buying the books to go along with it. Though if you'd like to argue the point that if I took the money I've spent on literature my truck would probably be on the road. lol
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
05-15-2014, 01:34 PM | #4 |
Re: more issues!!
well it is not that.if i could get my hands on a BOOK i would, i don't want a cd. that is all i can find. if i do find a book they are way too costly!
05-15-2014, 01:57 PM | #5 |
Re: more issues!!
What do you consider "way too costly"? I see one for 48.00 shipped to your door....
Seems pretty cheap versus a tow job because you didn't have the complete info when performing the job.
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
05-15-2014, 02:17 PM | #6 |
Re: more issues!!
Theres on in the forum classifieds for like $28 I think
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-15-2014, 02:47 PM | #7 |
Re: more issues!!
You are going to need a manual and since the small block is the same for many many years you can use the info from a later manual. A local library is a place to start. Also there are a few good you tube videos to help out. You will need a puller for the damper. I reccomend cleaning the pan and front cover good before starting and run the engine to find out exactly where the oil is coming from. I have seen folks change a rear main seal only to find out the oil pressure sender was leaking. Knowing exactly where the leak is helps do the correct fix. What ever you do don't use the blue silicone. It will cause issues. Use the black. It is much better and wont soften up.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-15-2014, 03:36 PM | #8 |
Re: more issues!!
Do note that a 283 lacks the balancer retaining/installation bolt in the crank snout.
05-15-2014, 03:43 PM | #9 |
Re: more issues!!
you need to find a mentor before you hurt yourself
05-15-2014, 04:10 PM | #10 |
Re: more issues!!
05-15-2014, 04:31 PM | #11 |
Re: more issues!!
283 front crank seal and balancer bolt mod
http://67-72chevytrucks.com/vboard/s...d.php?t=550482 |
05-15-2014, 04:33 PM | #12 |
Re: more issues!!
05-15-2014, 04:34 PM | #13 |
Re: more issues!!
thanks man!
05-15-2014, 04:48 PM | #14 |
Re: more issues!!
Rear seal and pan on an I6 but same procedure for 283.
PS-highly recommend BluGoo...its Gods own sealant! Naysayers are blasphemers. http://67-72chevytrucks.com/vboard/s...d.php?t=626090 |
05-15-2014, 04:52 PM | #15 |
Re: more issues!!
k! thanks. any info helps on this truck!
05-15-2014, 04:52 PM | #16 |
Re: more issues!!
If ya dont have a manual hit the faq....tons of how to in there.
05-15-2014, 04:56 PM | #17 |
Re: more issues!!
i will make sure to do that.
05-15-2014, 05:15 PM | #18 |
Re: more issues!!
If ya decide to use a gasket sealant tell no one here. There is a near irrational fear against its use thats nearly as silly as giant tires and a laid out frame. Ye'll read tails of 40eleven hundred torque diesel compression 87 octain mouse motors with spun rod bearings due to a floating chunk of goo when the real reason is failure to fit the bearing in the first place. Gasket goos are fine to help old warped tins seal when used appropriatly.
05-15-2014, 05:18 PM | #19 |
Re: more issues!!
hahaha!
05-16-2014, 05:52 AM | #20 |
Re: more issues!!
Read the Manual.
A lot of the parts vendors sell reprinted manuals... or you can still find 'em used. It will cost you more in aggravation and broken parts in the long run, by not having one to look things up in. They don't cover everything, but there is a lot of information in there that you can use. Publications & Print Resources -W Last edited by Woogeroo; 05-16-2014 at 06:54 AM. |
05-16-2014, 10:14 AM | #21 |
Re: more issues!!
ok
05-16-2014, 10:31 AM | #22 | |
Re: more issues!!
05-16-2014, 11:00 AM | #23 | |
C10 CLUB Y QUE!
Re: more issues!!
05-16-2014, 11:46 AM | #24 |
Re: more issues!!
some of us just toss the manual away! what a shame
05-16-2014, 11:53 AM | #25 |
Re: more issues!!
My truck is scheduled for an honorable end with dignity. Cremated with me. That way no next guy to chop it down or hogg it up wif getto wheels. Meantime, BluGoo keeps us rollin.
