05-15-2014, 01:12 PM | #1 |
possible tuning issue, over carb'd maybe?
so ive been posting about this truck I got, its a 1970 c-10 long bed. 350 with rv cam, edelbrock intake and carb spacer, and edelbrock 650 carb. msd ignition, long tubes, duals to flowmasters dumped at the axle, stock heads. this thing runs like a raped ape, but off idle is pretty bad. if I hammer the gas from a dead stop, it barely squeals the tires and has a real delayed bog, and then comes on once it recovers from said bog. im no expert but this thing outa rip the tires off the rim from a dead stop, it has the power, its just not tuned or something. any thoughts? maybe a 650 carb is too much with stock heads??
05-15-2014, 02:02 PM | #2 |
Re: possible tuning issue, over carb'd maybe?
The bog could be caused by the wrong size accelerator shot.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
05-15-2014, 02:29 PM | #3 |
Get online and download the Edelbrock tuning guide for your model of carb (if you don't already have one) without a tuning guide, you are shooting in the dark. These carbs are not that hard to work on. but without that guide in hand you will never get it figured out.
I am assuming it is a 1806 electric choke. If it is not... let me know. http://www.edelbrock.com/automotive/...&submit=search
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
05-15-2014, 11:51 PM | #4 |
ok I will check tomarro and get back with ya. ive done lots of efi, but never even touched a carb.
05-16-2014, 12:01 AM | #5 |
What's your timing set at?
05-16-2014, 08:13 AM | #6 |
Check the gasket under the carb, between the intake and the spacer. This intake / carb / spacer combo is bad to burn through on the passenger side secondaries and it will cause a huge vacuum leak. I personally have had one do this same thing to me and recently helped another guy on the board with the same problem.
Pull the carb and spacer and check the gasket I can almost promise you if you replace it the bog will go away.. look specifically at the edge of the gasket and mating surface on the intake. I'll watch the thread to see how it works out. Good luck man.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
05-16-2014, 09:09 AM | #7 |
Good stuff mentioned but there are a couple things you need to let us know.
What type intake? Single or dual plane. What type transmission? If auto, what stall converter? |
05-16-2014, 12:08 PM | #8 |
Matt, if you've never touched a carb (which was basically me before I got my truck) then the tuning guide may look as Greek to you as it did to me. I recently called Edelbrock and talked to a tech about my setup, and within 2 minutes he told me how to tune the carb for my particular engine.
You should buy the calibration kit for your model, it comes with an assortment of metering rods and springs, they are about $50-60 online at all the usual places. Edelbrock will want to know the lift and duration of your cam, hopefully you have a grind spec. What they told me for my RV cammed 350 was: - Set timing to 16 BTDC (I was at around 10) - Accelerator pump rod in top hole - Pink springs (each one in the set is colored) - Metering rod part # 1455 My cam is 234 Duration 488 lift (one of the experts on this board said it's equivalent to a Melling in a previous thread) Also, if you have a OEM mechanical fuel pump, Edelbrocks don't like a lot of fuel pressure, so you should add a regulator to bring the pressure down below 6 PSI. It will make it easier to tune (and run better). Most OEM pumps put out 8-9 PSI. IMO it's worth the 10 minutes on hold with Edelbrock to have them advise you. Nice to get it right the first time. Though changing out the rods and springs is easy and quick - 10 minute job, don't have to remove the carb from the manifold to do it. |
05-16-2014, 12:37 PM | #9 |
05-16-2014, 12:38 PM | #10 | |
05-16-2014, 12:45 PM | #11 |
[QUOTE=71tahoe;6675894]Good stuff mentioned but there are a couple things you need to let us know.
What type intake? Single or dual plane. What type transmission? If auto, what stall converter?[/QUOTE edelbrock performer intake, no numbers on it though so I couldnt tell you if its a dual plane or single, ill be brutally honest and admit that I actually dont know the difference, or whats better lol take it easy its my first old school and first chevy Tranny is a built th400, no stall, 3 speed auto |
05-16-2014, 12:48 PM | #12 | |
05-16-2014, 12:50 PM | #13 |
and I looked at the carb, the numbers are 1406 2094, dont know what this means but they are stamped right by the edelbrock emblem, hope that helps
05-16-2014, 12:54 PM | #14 |
Dual plane intakes give you more low end torque. In this case, the Performer is a dual plane.
An RV cam is a loosely used term for a cam slightly bigger than stock. The stock 350 cams in the trucks were 194/202* @.05 if I recall, an RV cam would be somewhere roughly in the range of 200/210*.
71 K20 64 GMC mud truck |
05-16-2014, 03:12 PM | #15 |
Your carb is a 600 cfm square bore with electric choke. 2094 is a catalog number I believe. I have attached a couple of photos to help you understand the difference between a dual plane intake and a single plane as well as square bore versus spread bore.
The first picture is a SPREAD BORE, DUAL PLANE manifold. You will notice that the openings get larger at the back and the mounting holes are wider at the rear than at the front. This is a SPREAD BORE application. Also, you will notice the divider in the center, making it a DUAL PLANE. The second picture is a SQUARE BORE, DUAL PLANE manifold. On this intake all the holes are the same size, and the flange is square. Again, there is a divider in the center making it a DUAL PLANE. The third picture is a SQUARE BORE, SINGLE PLANE manifold. Again, the flange is square but on this intake there is NO DIVIDER, making it a SINGLE PLANE. Welcome to the forums, and remember... there are no dumb questions. You have come to the right place. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-16-2014, 03:50 PM | #16 | ||
"I ain't nobody, dork."
You need to nail down timing first. You need a timing light to do it. Also make sure the transmission kickdown is working properly (if an Auto tranny).
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-16-2014, 04:03 PM | #17 |
thank you that is very helpful. I was under the impression that an rv cam was much bigger than stock, thats dissapointing to hear its a small cam....I tell you what it lopes like a beast, cant beat the idle sound at all
05-17-2014, 09:39 AM | #18 |
still tryin to find some time to check all this stuff out, goin to school full time but ill have some answers here soon
05-17-2014, 10:01 AM | #19 | |
Always dial in timing first. Make sure your vacuum advance is correct for your application, the mechanical advance is free and working. Post up your initial and at 2500 RMP (vac disconnected), and at 2500 with vac connected. Should be something like 14-16 initial, 32-34 at 2500, and then with vac connected 50-52 at 2500. Your engine may respond better at different readings.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-17-2014, 10:36 AM | #20 |
Fellas I agree 100% on timing however the fact once it goes over the 'bog' on initial acceleration it's fine.. which kinda makes me think vacuum leak or carb, accelerator pump etc.
Let's just say I replaced my engine.. yes the entire engine with a 350/290 HP crate motor. When we moved the intake and carb over to the new crate motor.. The problem moved with it.. that's how we found the carb gasket I posted earlier. $5 fix. .. I fought with it for months. Dist, fuel pump, all new fuel lines, etc. We tried everything to get that stumble out of it. Mine was a 69 Camaro.
05-17-2014, 12:29 PM | #21 |
One more for checking initial timing! You've got to start there.
05-17-2014, 05:05 PM | #22 | |
05-20-2014, 11:01 AM | #23 |
still gettin to it....who's idea was it to have kids anyway! lol
05-28-2014, 11:19 AM | #24 |
You know how that works right? Kids are usually the side effects of a sheets & pillows party. But then after you have 'em, you wouldn't trade them for the world... well, most of the time.
05-28-2014, 02:30 PM | #25 |
