Knuckle Buster, Instructor
![]() Join Date: May 2010
NP 205 speedo gear. Where do you find them??
My 72 Blazer made the driven gear for my speedometer in the 205 look like an apple core. I have the solid metal style. Does anyone know where they can be found? At this point, I don't even care if the teeth are wrong. If they are, I'll use a ratio adapter.
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
Re: NP 205 speedo gear. Where do you find them??
1972 K2500 Long Box 400/350 |
Thanks...but both of those are drive gears. I need the driven gear that the cable slides into.
This is what I'm looking for.
I looked hard i can't find it used or new.Wonder if a newer np205 one would work or not?
I've got one that the gear is good on but it has a cable broken off inside it. The other I have has the worn teeth. I'm going to see if a machinist friend can make me a new one. I wish I knew if the newer stuff would work. I was sure hoping someone had a gear.
let me go kick around in my pile of 205 stuff. i may have one.
That sure would be great if you have one. Please let me know.
Have you tried http://www.quad4x4.com/New_Process_NP205_Parts.html i didn't look through there just posted the 205 link, i ordered 205 shims from them no problems
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
Or call them it looks like they have just about everything else for it.
IIRC, there are four different gears. You might want to calculate your tire and final gearing to pick the closest gear.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#13 |
Did you ever find one? I got one off of a Dodge and had a hard time finding one at that. Ford is different. I tried Quad 4x4 and it had been discontinued. I ended up buying a tail housing with the housing, drive and driven gears off of evil bay. Was around 125 with shipping. It was expensive but I was pretty desperate.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#14 | |
#15 |
Now that's "run whatcha brung"! Glad it worked out
#16 |
Guys, mine works great but I have friend building a truck and his 205 is missing the gear. I still need a gear for him if anyone has one.
