headlight
what would cause the right to work on bright and dim but the left side doesent work on dim. I have changed the headlight but have the same problem. Do the headlight feed from drivers side to the passenger side?
![]() Join Date: Apr 2012
Re: headlight
Yes it goes from the drivers side to the passenger. Sounds like a bad connection. Do you have a meter to check for volts at the connector?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
Re: headlight
If you have some spray contact cleaner, spray the (wiring harness side) plug. With it disconnected of course:-)
Re: headlight
I had similar issues, but only had high beam on one side. Wound up playing around wiggling wires and plugs and found the one headlight connector was getting a bad connection. I tried to clean it and bend the contacts inside a little, but it didn't help and I wound up breaking the plug.
Got 2 parts store plugs, spliced them in and problem solved.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Re: headlight
My truck was doing the same thing. I replaced my high beam foot switch and it fixed the problem
Re: headlight
I had a similar issue as well, I removed the plug at the back of the headlight and used some sandpaper on the male prongs of the headlight. Pluged it back in and it works fine.
72 C10 350/TH350 |
I built it
Re: headlight
when i first got my truck the only headlights that worked were the high beams. looked over the wire and by the fuse block the low beam wire had a hole burned in it. ran a new wire from the dimmer to a better spot on original wire and they then worked.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: headlight
My right headligt just stopped working one day. Pulled the headlite, bench tested it and it worked. I cut the old connectors off, soldered and heat shrunk new ones on and that cured the problem.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: headlight
I appreciate all the feedback and I will post what I do that fixes the problem.
![]() Join Date: Feb 2002
Re: headlight
Check the headlamp plug ground wires behind the battery box on the radiator bulkhead. They can corrode, get chewed by packrats or just work loose.
