Clutch hyd to linkage 63 gmc
I haven't looked yet at the pedal set up ....what will it take to go FROM hyd. clutch to linkage on a 63 GMC ... I know the obvious bell crank and bell housing ...mainly under the dash is the question .... then i can use power booster and dual brake master truck has V6 now putting V8 in..... has anyone done this? ..i tried search did not come up with much
Re: Clutch hyd to linkage 63 gmc
Simply plug the line on the master cyl that goes to the Hyd cutch and it should work. I changed the clutch linkage on my 62 GMC to mechanical it required making a hole in the firewall for the release rod and welding a bracket to the frame to mount the bellcrank. Mine wasn't power brakes but I still used the same dual resevor master cyl. Just plugged the one side.
I just removed a frame mount for the z-bar....pm sent
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
