Old 05-16-2014, 06:41 AM   #1
MUMBO
Build dates
Hi I live in Australia and resently bought a unlicensed 1973 C10 what I need to find out is there a way I can find the build month I've worked out the year no worries ?
The reason I need to no is if it was built before July 1973 it doesn't have to comply with Australian ADR rules so I don't have to get it inspected by a engineer.
I have the VIN number and chassis number but there is no build dates any where to be found.
VIN #CCY143Z------
Chassis #C3Z10----
Any help would be greatly appreciated
Thanks Kev
MUMBO is offline   Reply With Quote
Old 05-16-2014, 07:37 AM   #2
buddy_1
buddy_1's Avatar
Re: Build dates
Have you checked with your local auto dealer? If you PM me the full 13 digits, I will check with our parts department to see if they can decode it. I can't make any promises though, sometimes they are too old to come up in the catalog.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 05-16-2014, 08:06 AM   #3
MUMBO
Re: Build dates
That would be good mate
Old 05-16-2014, 10:50 AM   #4
bdiamond
Re: Build dates
Could you use casting dates as info for documentation? Heads and blocks have them. I thought the trim tag had date info also.
bdiamond is offline   Reply With Quote
Old 05-16-2014, 12:55 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Build dates
Would be on the blue tag in the drivers door jamb. Chances are very very very good it has a build date before July since by August they were making the next year models.
First photo you can barely make out the 04 / 73 in the top right corner. Second photo it is very clear on the 74 model of a production date of 08 / 73 (was a 74 model).
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-16-2014, 05:28 PM   #6
MUMBO
Re: Build dates
Thanks for your help guys , I can't use engine cast dates as it's got a 454 in it was factory 350 and that tag seems to have been removed probably when it was painted years ago.
Old 05-18-2014, 12:13 AM   #7
buddy_1
buddy_1's Avatar
Re: Build dates
I had them run the VIN and the catalog showed the basics but the build date line was blank. Sorry I couldn't help, Buddy.
Old 05-18-2014, 01:52 AM   #8
80SPORT
80SPORT's Avatar
Re: Build dates
Put your full vin up here and it should we should be able to estimate build date by comparing with known build dates from the same plant.The plant vins should be in sequence starting with 100000 typically.
Most likely was built before July as most plants would be building 74s by then
80SPORT is offline   Reply With Quote
