Old 05-16-2014, 08:23 AM   #1
71sixgun
A new 1 bbl?
My 71 has got a 250, and sat for 15 years, and you can imagine the crud built up in the carb! I got it running, the float bowl is cracked, and the adjuster screw has no threads! Has anyone seen a rebuilt rochester? what are some sites that I should try? I just want to keep it simple...for now!
71sixgun is offline   Reply With Quote
Old 05-16-2014, 11:15 AM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: A new 1 bbl?
Rock Auto has them for 125.00 if you send your core back, 174.00 if you don't...
Actually - it looks like the 125.00 price is if you ship yours in to be rebuilt.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-16-2014, 11:46 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: A new 1 bbl?
I bought a rebuilt one about 18 yrs ago and wound up having to take it back couple of times. Finally gave up and started doing it myself. I picked up a couple used ones on ebay for under $30 each and rebuilt them.
Also, be aware that some companies won't accept one that's not rebuildable.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-16-2014, 12:40 PM   #4
JustCallMeDrew
JustCallMeDrew's Avatar
Re: A new 1 bbl?
I rebuilt mine...went to the closest auto parts store and ask them for a rebuild kit and it was $18
1968 Chevorlet C10 work in progress no build thread yet!
JustCallMeDrew is offline   Reply With Quote
Old 05-16-2014, 01:41 PM   #5
slowcpe
slowcpe's Avatar
Re: A new 1 bbl?
I bought mine from Summit
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 05-16-2014, 01:53 PM   #6
Matt Cramer
Re: A new 1 bbl?
I haven't been very impressed with parts store rebuilds - in the interest of cutting down on part numbers, a lot of those big rebuilding houses mix and match parts from all sorts of different years and often end up with carbs that are a drivability nightmare. I rebuilt my first carb in my parents' basement at 18 with no idea what I was doing, and had better results than many "professionally" rebuilt carbs. Either overhaul it yourself, or find a local carb guru who can take care of it for you. I wouldn't touch a parts store rebuilt carb.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 05-16-2014, 05:39 PM   #7
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Re: A new 1 bbl?
Back in the 80s those were like $39 at advance auto , id say today summit would be your best bet !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
