Old 05-16-2014, 11:25 AM   #1
bonehead
bonehead's Avatar
Converting TH400 auto to NV440 manual
I am collecting parts for my 1966 C-10. In the fall I am planning on changing over from a TH400 auto to a NP440 manual.
My truck had the stock transmision crossmember removed by the PO, so I will be using a rear tranny mount from the auto moved to the new location for the manual trans. So I have to use an aluminum bellhousing instead of a cast iron one, or should I use the cast iron stock bellhousing without the bellhousing mounts? I will have to get the different starter too.
I have found the following bellhousing for a good price:
#460486
SB & BB with 5 1/8” center hole
Ball boss
Aluminum
12” clutch
168 tooth flywheel
My question for you experts is can I use the stock cast clutch fork with the aluminum bell housing? The rest of the clutch lingage will be stock 1966 as well. I did a search and did not see this info.
Straighten me out if I have some of this info wrong please.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 05-17-2014, 05:11 PM   #2
bonehead
bonehead's Avatar
Re: Converting TH400 auto to NV440 manual
Does anyone have this info?
Can I use an aluminum truck bellhousing with the 1966 truck cast clutch fork?
I thought I would simplify the question. Thanks in advance.
past trucks:
Old 05-18-2014, 11:08 AM   #3
par4tom
I think you can go either way. The NP440 has the rear mount bolt holes so that option is available to you.
I used the cast iron bell housing with this tranny in my truck and the stock crossmember in its original placement and it's worked out fine without using the rear support.
I am using the hydraulic clutch though...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 05-19-2014, 07:58 AM   #4
bonehead
bonehead's Avatar
Has anyone used an aluminum bell instead of the iron bell? If so what clutch fork are you using?
I'm starting to think that the iron bell is the simplest way to go with an added on rear tranny crossmember, since my original crossmember is long gone from the PO's hack of my truck.
I can use the rear crossmember from my TH400 and just reposition it.
past trucks:
Old 03-03-2015, 06:35 PM   #5
ljackson
ljackson's Avatar
bonehead, did you make the swap?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 03-04-2015, 09:08 AM   #6
bonehead
bonehead's Avatar
The swap has been put on hold while I am waiting for my new house to be built. I am still planning to do the swap this summer. I have most parts sourced or in hand except for the driveshaft.
I will start posting on this as things progress. Thanks )bone(
past trucks:
