Old 05-16-2014, 01:01 PM   #1
outlawmatt
Cab and chass rear end
Will the rear end out of a 73 c/c fit on a 67 C10 with coil overs?
i would like to put a dually rear end in my truck.
outlawmatt is offline   Reply With Quote
Old 05-16-2014, 04:36 PM   #2
outlawmatt
Re: Cab and chass rear end
anyone?
Old 05-17-2014, 04:45 PM   #3
airdale94
airdale94's Avatar
It will fit and it has been done. You will need to weld in new spring perches. CaptainFab over in the 60-66 forum has them. And you will need a adjustable pan hard bar to get the rear centered side to side. The CC rear will put the wheels completely in the bed so the wheel wells will have to be widened. Try the search somebody documented this really well on a build. I just did this with a single wheel. My post has a couple of links in it.
http://67-72chevytrucks.com/vboard/s...d.php?t=625694
Sorry, I believe the CC rear was swapped in a leaf spring truck.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
