Old 05-16-2014, 01:08 PM   #1
eighteenninetytwo
Anyone ever used a paint stripper to remove factory paint
this would be to get it to bare metal without either blasting it or spending a ludicrous time and effort sanding things down to bare.
eighteenninetytwo is offline   Reply With Quote
Old 05-17-2014, 09:23 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Anyone ever used a paint stripper to remove factory paint
I've seen it used but never messed with it myself. Is this for the bedliner?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-18-2014, 01:27 AM   #3
eighteenninetytwo
for the tailgate I got from pick n pull. Just wondering how to approach it. Some areas I will have to sand to bare metal and apply no-rust or POR15 then primer: Some have factory paint still. Trying to figure whether to sand it all down (crazy effort time money etc) or whether to try to build up the areas which will be bare metal to the level of the factory paint. with lots of layers.
Old 05-18-2014, 09:31 AM   #4
68Timber
68Timber's Avatar
I would not take it down to bare metal in areas where you still have factory paint. Are you using rattle-can paint? Rustoleum sells a grey filler primer, Walmart carries it in their automotive section. I've had good luck with it.
John
74 Honda Z50 build
Old 05-18-2014, 04:38 PM   #5
Edahall
You can sand off the paint in no time with a 1/4 sheet sander using 80 grit sand paper.
Afterwards, use epoxy primer on the bare metal.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
