Old 05-16-2014, 01:41 PM   #1
CATCHALLBLUE
CATCHALLBLUE's Avatar
Master cylinder change '69 C30
Howdy all,
Just pulled my '69 C30 292 out of its garage tomb. Put in some gas and it started right up!
So far i have changed the oil and filter, the fuel filter and air filter. Never done a master cylinder before. Any procedures/precautions i should follow?
Any other minor repairs/checks i should do?
Let me know what you think....
CATCHALLBLUE is offline   Reply With Quote
Old 05-16-2014, 06:09 PM   #2
SS Tim
SS Tim's Avatar
Re: Master cylinder change '69 C30
First off start with a factory service manual.
Review any service as much as possible from it.
As far as needed service I'd suggest performing a major level service as outlined in the service section that will give you all the grease points and inspections. Setting is never good for a vehicle.
On the brakes, if you need a master there is a good chance you need wheel cylinders too. Probably all of them. If it were me I'd start by trying to crack open the bleeders. Once you change out the master the system will need to be bled even if the hoses,lines and cylinders are good. Since at least one old bleeder is going to try and break, look into cylinders and such up front before it is up on blocks immobile again. If the master leaked into the booster it needs to be replaced too. Stock replacement drums are not available as far as I know. If you need a lot of parts, discs from a 72-88 C30 make more sense.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio)
* Post Your Pickup SPID Blazer SPID Suburban/Panel SPID
* RTFM
... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 05-16-2014, 07:06 PM   #3
CATCHALLBLUE
Thanks for the advice Tim,
I received the Haynes manual in the mail today. The manual says to change the MC then bleed the lines.
Im also having an issue with cold starting. It seems i have to pour gas into the carburetor and pump the gas to get her to start. Any ideas?
Old 05-16-2014, 08:15 PM   #4
SS Tim
SS Tim's Avatar
A Hanes is not the same as the factory manual but is good to have. I am strongly suggesting you buy a factory manual as well. However there are copies that can be downloaded too. They are linked in my signature above, "RTFM" in red. Most are there IIRC you might need to download a 70 for Chevy as the 69 are GMC, just a minor difference for your needs.
Yes I understand "change the MC then bleed the lines". My suggestion was to start at the bleeders and see if they will even open. Often they are frozen or break off. Better to know what you are dealing with before than after the trip to the part store. More so if you only have "screen readers" at the parts store vs people who actually know parts.
Depending on how long it has been sitting the list to get it safe and road worthy can be long.
The carb probably needs a rebuild.
Old 05-17-2014, 09:03 AM   #5
CATCHALLBLUE
Much appreciated Tim,
I will be on my back inspecting the undersides today.
Dont see the link in your signiture. But i did come across the post with the manual links a couple days ago while browsing the forum. Now I dont know where it is. When i clicked the '69 manual it didnt load. Maybe the file crashed?
Old 05-17-2014, 09:35 AM   #6
JointTech
JointTech's Avatar
bench bleed the MC before installing it or youll be bleeding the brakes for days.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-17-2014, 10:35 AM   #7
CATCHALLBLUE
ahhh ok good advice.
I forgot to mention my truck is a dually. Does that change anything when bleeding the rear brakes?
