05-16-2014, 07:57 PM | #1 |
Removing a panel floor
Does anyone if a panel floor comes out in one piece or a piece at a time? If so does it come out through the bottom?
05-17-2014, 01:23 PM | #2 |
Never Ending Projects
Re: Removing a panel floor
No, the floor on a panel truck is two pieces, with the joint in the middle. The floor comes out from the top. From what I can tell on mine, you would removed the middle strip and make sure none of the other strip bolt go through any frame mounts. You then lift up the floor from the middle and slide it over the other side, enough to clear the lip around the wall edge and then remove. Pull the other side out from the lip and remove. Floor is two pieces of plywood.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-17-2014, 06:06 PM | #3 |
Thanks for your response, i took mine out today and was just as you say.
