Light switch knob removal?
I need to remove my new light switch that I installed a couple weeks back because I will be replacing the wiring harness. For some reason, I can't seem to get the knob to separate from the switch. I remember you need to pull the knob all the way out, to the "lights on" position and then push a release button. This switch that I installed, which I believe is an aftermarket switch even though it looked exactly like the original, doesn't seem to have any release button. There is a spring loaded type button on the side opposite the side where everything plugs in. Is that the release button?
Re: Light switch knob removal?
yes thats it ....pull the knob out and push the little pin in ....some times you kinda have to wiggle everything some
early classic - tach. install article
it's two or three pages, check the links at the bottom of the page. I only include it as it has photos and explains the head light switch removal process and reinstall. remember to disconnect the battery too. -W |
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
