05-17-2014, 12:00 PM | #1 |
Where to get 5 lug kit for my 70 c10
Ok guys I finally have some funds to do some wheels on my truck prob is the wheels I want are 5 lug and I been wanting to do a 5 lug conversion on my truck anyway. So what's the best kit as far as price I want the cheapest price ocourse but good quality. So what y'all guys going with and from where. Thanks guys for any help!
05-17-2014, 11:13 PM | #2 |
Re: Where to get 5 lug kit for my 70 c10
Anyone?? I know there is a lot of guys who have done this!
05-17-2014, 11:49 PM | #3 |
I'M NOT SCARED I HAVE A PLASMA
You can run CPP drop spindles. You will need to change out the ball joints because the Squarebody ball joints are bigger. Then you get some 1.25 rotors from a Squarebody at the parts store. You will need calipers also. If you can find a truck around the same year as yours that is 5 lugs pull the axles put them in yours. Get some new drums. Personally I would put 9" Ford housing ends on your rear and get new Axles from Moser
Lou Santiago US Navy Retired/World Traveler Car Builder/Welder/Airport Investigator garageinsidertv.com [FORUM] WORK IS FOR PEOPLE WHO CAN'T FISH. I GUESS I'M SCREWED BECAUSED I HATE FISHING. |
05-18-2014, 12:45 AM | #4 |
http://www.earlyclassic.com/ has front and rear kits.
05-18-2014, 12:10 PM | #5 |
A front brake swap from a donor 71-80 gets you the parts you need for budget 6-to-5 lug swapping. Aftermarket drop spindles & 73-80 brake parts from a parts store is a little more $$ but everything is new 5-lug stuff.
For the rear, I always recommend swapping in new, fresh axles w/zero wear over spending the $$ re-drilling the pattern into your 44yr old parts. Moser makes 5-lug axles that swap right in & then you just need brake drums for a 71-72. I know Lou recommended the Ford housing ends above but they aren't necessary if you just want the bolt pattern change (a good idea/upgrade though) ECE makes a 6-to-5 lug swap package but you pay for the packaging vs DIY.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-18-2014 at 12:15 PM. |
05-18-2014, 01:14 PM | #6 |
Guys I appreciate the help! I knew that I could prob just buy 71 and newer parts but would cost a lot more than some of the kits that
Are out there so that's why I wanted to see what you guys Suggested and were doing. |
05-18-2014, 01:32 PM | #7 |
So another question what if I just buy everything for a 71-72 c10 out of a Lmc catalog or classic industries etc will everything work for my 70 in order to get the 5 lug and disc brakes like I want
05-19-2014, 11:17 AM | #8 |
Yes.... but you will pay more for it.
09-18-2014, 10:34 PM | #9 | |
09-18-2014, 10:34 PM | #10 |
09-18-2014, 11:31 PM | #11 | |
even used a 86 steering wheel |
09-18-2014, 11:39 PM | #12 | |
Good deal!! I'm not getting the entire truck, just the front and rear assemblies. What should I grab off the front. Do I need to grab the steering box too or can I use mine for now and do a PS upgrade later? I'm grabbing the brake booster and proportioning valve as well |
09-18-2014, 11:41 PM | #13 |
Steering components? or just get a rebuild kit from the parts store for a square body?
09-19-2014, 11:36 PM | #14 | |
09-20-2014, 01:52 AM | #15 |
09-28-2014, 10:27 PM | #16 |
I just did the rear swap on my 69. I ordered the kit from speedway. Cheapest I found it and had it in 3 days. Was surprised to find out it was a cpp kit. Took about an hour to make the swap.
