need some smog information
I was just curious if on a 327 in 67 would the 4bbl carb be different on an engine with and without smog? I am doing a restoration and have found the correct 1967 smog equipment but am unsure if my carb will work with it properly. also is the distributer weighted differently with smog ? Are there differences in the mixture control valves and smog pumps from motor to motor and if so what would be correct for a 67 327 275hp? any info is appreciated. Rod.
Re: need some smog information
nobody has any info?? I looked in the 67 service manual and it says that the carb and distributer are special for this application but I was wondering if the carb is actually jetted different and the dizzy just weighted different of completely different part #'s.
Maybe you could offer some info.
What smog equipment does it need? Why a 275 hp motor? Wasn't the 220 hp motor the only one available? |
the motor is from a chevelle. that's why 275 hp. More than anything I just need general information before I make a purchase on some smog stuff.
here are some pic's of a 67 with smog. its a little different than 68-up smog equipment. I basically need to know if the carb and distributer I have with no smog will work with the smog equipment.
