Old 05-17-2014, 05:53 PM   #1
Sean1985
Sean1985's Avatar
Alignment issues?
Anyone with a 5 or 5.5 drop in the front have any alignment issues. I talked to ECE and they said you can't align these trucks with more than a 4.5 drop. Just curious before I order all my parts. Thanks.
Sean1985 is offline   Reply With Quote
Old 05-17-2014, 06:19 PM   #2
tinydb84
tinydb84's Avatar
Re: Alignment issues?
If you do 4.5 inch spring drop only then you wont be able to align it. A combination of spring and spindle drop and you will be fine.
David
Instagram: myfabguy
Old 05-17-2014, 06:23 PM   #3
Sean1985
Sean1985's Avatar
Ok that's what i thought. Maybe I was not clear when I spoke with them. I plan on a 2.5 spindle and 3" spring. Thanks for the reply.
Old 05-17-2014, 07:51 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It will align just fine as long as the rest of your suspension is good and not sloppy.
