Cpp C -Notch 60-62? #6372cnk HELP
Looking to buy a C notch kit. Cpp has a part number "#6372CNK 1963-72, kit". The question I have is why only 63-72? Why would this notch not work on a 1960-1961-1962?
I have a 1961 C10 I am looking to notch. Would it work on my application? |
Re: Cpp C -Notch 60-62? #6372cnk HELP
different frames , 63-72 had ladder bar frame and 60-62 has x-frame...ive only had 63-66 trucks so I cant tell you for sure why, but I assume the frame curvature on the 62 and under is different above the axle area where the notch would need to be installed...
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
heres a 60-62 x-frame , if you notice its pretty straight on the side rails of frame looks to be close to the same width all the way back to the rear frame :
http://i311.photobucket.com/albums/k...a/IMG_8214.jpg http://img16.imageshack.us/img16/1973/060qvx.jpg and here is a 63-72 frame you can see they are totally different and that the ladder bar frame curves/tapers back in towards the rear so the rear frame width is smaller dimension width then the middle of frame and the c-notchs are made with this taper in them: http://i1178.photobucket.com/albums/...23Nov11001.jpg And that there is the reason the 63-72 notch will not work on your frame heres a simple pipe notch in a x-frame http://67-72chevytrucks.com/gallery/...425x425Q85.jpg
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 05-18-2014 at 01:22 AM. |
If a little notch is needed use 5" pipe to get where you want. Or PorterBuilt has big ones. I did 2"
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Ride height. Stock torsion front for now. Have PorterBuilt front crossmember to be installed.
#6 | |
What rearend are you using? |
The 62 frame is boxed in that area from factory. Bottom pic shows inside frame.
![]() Join Date: Oct 2013
Do you have any pictures of the inside of the frame after notch??
It's a pipe. Solid and frame is boxed there.
Zoomed in.
Who Me?
I would only go halfway thru the frame with the pipe notch and also boxing it. I thought of doing this, but I pull a trailer from time to time and worry about the strength after a mod like that.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
The 60 to 62 frame is already boxed at that point. Used a 5 inch pipe and made 2.5" notch.
#13 |
How thick of pipe did you use?
#14 |
i did this mod as well using 5" i.d. pipe. It was schedule 40 so 1/4" wall. I think it should hold up just fine
1960 short bed fleetside factory 4x4 1960 panel 454 NV4500 Daily driver 1961 Short Bed BBW Fleetside 5.3 th400 swap in process |
#15 |
3/16" I believe.
#16 |
#17 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#18 | |
#19 |
Contact Porterbuilt.
They make all their parts per your order. They won't sell you parts without talking to you first. Great product. Even better customer service!
#20 |
#21 | |
QUALITY PRODUCTS!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-10-2016 at 02:40 PM. |
#22 |
The standard Porterbuilt arms will work with the adjustable links. I opted for 1/2 longer. The bags are Firestone 2500 but 2600 that are on front might be a little softer. Nate and Dave are great with answers.
I went 1" drop built in, there is a 3" as well.
#23 | |
Posted via Mobile Device |
#24 |
#25 |
No. The lower one is stock arms ,boxed and powder coated black.
